How to clean without removing Ring gear and diff, Lots of gunk in tranny |
DNHunt |
Oct 31 2005, 09:27 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Ok, i'm looking for suggestions. The gear stack is out and there's a bunch of gunk in the rest of the transmission case. Whats the best way to get as much out as possible? I don't want to remove the ring gear and differential.
Dave |
Aaron Cox |
Oct 31 2005, 09:30 AM
why not? open up the side cover. pull em out. clean it out, put it back. (the smae way it was)
as long as you use the same total gasket thickness on the int plate, your pinion depth will be right. pull the sidecover, after pulling the output flanges.... clean to your hearts content oh... and if you put it in backwards, you havd 5 reverse gears (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
ClayPerrine |
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Removing the differental will not hurt a thing. The adjustment is done with shims that are between the bearings and the differential carrier. Just pull the side cover and lift out the differental.
Plus, You need to replace the o-ring on the differental cover if you are this far into the tranny. |
DNHunt |
Oct 31 2005, 09:40 AM
Ok, Thats great to know. Taking this thing apart is really fun. The cleaning is not so great and buying parts is no fun at all. Both intermediate plate bearings fell apart. I'm going to try Gary Emory at Parts Obsolete and see if he has any reasonable used parts. He's got a lot of stuff in that big old barn.
I'm getting to like the smell of tranny fluid. It's right up there with MEK. Dave |
Aaron Cox |
Oct 31 2005, 09:42 AM
wait till you take apart one that has late 60's oil in it. i almost vomited...... look on ebay. Carquip (iirc) is selling new FAG bearings. or call matt and tom direct...... or hit up your favorite parts Haus..... |
Joe Ricard |
Oct 31 2005, 09:56 AM
Hey don't tell him the secrets to Transaxle repair. Let him screw it up so we can all laugh at him. Remember a few months ago when I did that very thing. Remember the book is wrong. ring gear teeth point towards the cover (914 configuration). teeth pointing in 911 configuration. |
rhodyguy |
Oct 31 2005, 10:23 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
this would be a great thread if it had lots of everyone's pictures of transmission tear downs and text.
k |
Joe Ricard |
Oct 31 2005, 11:36 AM
Yea I can post a picture of what not to do. Don't leave you intermediate plate and other parts in a rubbermaid box on the bottom shelf. DURING A HURRICANE! Did all ya'll know that magnesium and salt water DON'T mix. the plate is almost no more. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:39 AM |
