> shaky suspension ?, all new but still slight shiver
michelko
post Nov 1 2005, 10:53 AM
Hi everybody,
have a mysterious suspension problem.
Sometimes on a bumpy road the car is shaking a bit side to side.
Changed the tie rods to turbo style, mounted bump steer kit, adjusted the toe in to factory spec, every screw connection is fastened. what else can i do (check)?
Any body know this problem or the remedy?
I am sure it is not the bump steer problem!!!
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif)
3 Pages V  1 2 3 >
Replies(1 - 19)
Aaron Cox
post Nov 1 2005, 10:58 AM
Professional Tinkerer
was it aligned afterword?
is your car lowered? thus you used a bumpsteer kit?
Joe Ricard
post Nov 1 2005, 11:04 AM
CUMONIWANNARACEU
Define shaky. like going over bump in curve and the wheel trys to jerk out your hands. or like shake and shimmy like tire out of balance or wheel bearing loose.
michelko
post Nov 1 2005, 11:15 AM
it feels like the whole front of the car is moving from left to right. fast and short .
Not the shaking steering wheel if the car is lowered to much. The steering wheel is not moving while the symptom is happening.
It is realy hard to explain (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
lagunero
post Nov 1 2005, 11:18 AM
Donkey Member
lug nuts tight? new tires grabbing grooves of road?
SLITS
post Nov 1 2005, 11:19 AM
"This Utah shit is HARSH!"
Rain grooves in driving surface?
Shitty roads
Poor quality / old tires tracking in ruts / grooves.
Loose wheel bearings
To much toe (neutral or out)
Check rear trailing arm bushings for detoriation..
Check front bushings for same
michelko
post Nov 1 2005, 11:39 AM
tires are new.
wheel bearings not checked till now but no abnormal noise from them.
Toe in adjusted to factory spec 20` (+- 10`)
A-Arm buschings and trailing arm bushing not checked now. How is this done?
michelko
post Nov 1 2005, 11:41 AM
a forgot: anti roll bar in, no difference!
goose2
post Nov 1 2005, 12:30 PM
shocks?
Allan
post Nov 1 2005, 12:31 PM
Teenerless Weenie
Bent wheel?
SLITS
post Nov 1 2005, 12:54 PM
QUOTE (michelko @ Nov 1 2005, 10:39 AM)
tires are new.
For rears....put on lift....try to push wheels sideways...watch trailing arm attachment (especially the inner attachement) for movement
For fronts, the same principle...but wheel would move more fore and aft around the torsion bar ends. You would have to carefully watch the attachment points
The wheel bearing check is not noise....it would be rocking the wheel in a vertical plane to see if they were loose....grab top and bottom and try to rock them to see if there is any movement about the spindle.
Hey, we're guessing here.
You said the steering wheel doesn't shake...you said the car darts back and forth while holding a straight line.... Please correct me if I am wrong......
Joe Ricard
post Nov 1 2005, 01:06 PM
CUMONIWANNARACEU
Yea, I agree now it sounds like you need to go inspect stuff.
I bet loose wheel bearings
followed by worn suspension: shocks, bushings or mounting points in that order.
Thorshammer
post Nov 1 2005, 01:32 PM
How wide are the front wheels and where is the caster set at???
Erik
r_towle
post Nov 1 2005, 04:55 PM
Custom Member
I chased a shimmy for quite a while...
I changed everything...
I found two things.
First was the bottom of the strut tube where the ball joint is installed, the round hole that the ball joint slides into was out of round...this created a wobble .
The second was simple, but annoying.
The rear of the torsion bars has a felt washer over it. It ensures that the torsion bar stays centered.
Well, after 30 years, the felt is gone...I replaced it with a rubber washer. This stopped the clunk.
Rich
michelko
post Nov 1 2005, 11:33 PM
QUOTE (SLITS @ Nov 1 2005, 10:54 AM)
tires are new.
Yes there is a little play if i rock the wheel in vertical.
But i thought it´s normal my BMW makes the same thing and hasn´t the shaking.
And yes, the steering wheel is stady, it is the body of the car that is moving from side to side (not front to rear).
btw. thanks for all the tips. much work for the next weekend (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
michelko
post Nov 13 2005, 01:58 PM
After some inspection of the suspension parts, changing (again) the shocks, allignement, wheel bearing etc. i can´t find anything wrong with the mechanic, so i think its a problem of the tub itself.
I read about a mercedes cabrio that made this shaky also when driving over a railway crossing.
I purchased the Engmann-kit months ago, i will mount it over the winter.
I am in the hope that this will cure the problem.
Unfortunately i don´t know any other running 914 in the area to take a test drive (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) .
r_towle
post Nov 13 2005, 05:41 PM
Custom Member
vertical wheel shake on the front tires is the ball joint.
Have a friend shake the wheels while you feel the bottom of the strut tube...it was really hard to find, and really hard to feel, but a little wobble or shake in the lower ball joint will be drastic on the road...
Rich
Spoke
post Nov 13 2005, 10:31 PM
Jerry
Had the wandering thing also. Tie rod ends were shot, replaced with turbo tie rods, wandering reduced but not gone. Checked front end by jacking up one side at a time, and grabbing the wheel, shake back and forth, up and down and found out the ball joints were bad.
After new ball joints, things got much better, but still had some play which was from the wheel bearings not being tight enough. Tightened the bearings and now the car is nice and tight.
Spoke
michelko
post Nov 14 2005, 12:30 PM
QUOTE (Spoke @ Nov 13 2005, 08:31 PM)
Spoke
maybe that balljoint way is something i could try out bevore i throw it away (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) . they are not too expensive.
Eric_Shea
post Nov 14 2005, 12:39 PM
PMB Performance
Hey Rich... Check this out!
I agree with Rich. This is a problem that Porsche has recognized and posted in their Upfixen series. Early ball joints can wallow out the bottom of the strut causing exactly what you are describing.
Also, sounds like you need to either tighten or replace your wheel bearings based on this comment...
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 2nd May 2026 - 03:17 AM
