scottz0369 |
Newbie ![]() Group: Members Posts: 23 Joined: 30-September 05 From: 29 Palms, CA Member No.: 4,894 ![]() |
I drove from San Jose to 29 Palms, Ca on Sunday--
The '72 made it without much drama. I got about 28mpg cruising at 75-80 the whole way (1.7l with dual 40idf Webers). The car ran great with just a bit of valve clatter coming up the Grapevine in 4th. The Odometer (both trip and total) started working intermittently about halfway there, and I noticed the speedo needle bounces quite a bit at low speeds--is this a cable issue? Also, the dreaded "hot start" issue reared it's ugly head--after about 100 miles, I had to stop for a break--the car wouldn't start--no click, no starter turning, nothing. So I had a cup of coffee, came back in a half hour, and it started right up. The second time was just south of Magic Mountain--this time it sat for almost 2 hours, and still didn't start. I push started it in a really small parking lot. I left it running the rest of the way to 29 Palms. I think I need to get the Bosch hot start kit unless someone else has any ideas of the cause. Other than that, it was a great drive, and more comfortable than I expected. I found my digtial camera, so hopefully I'll be able to post some pics soon! Scott |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
waste of money. get a new starter now, as this one is about to die ... glad you made it OK! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Andy |
porsha916 |
Member ![]() ![]() Group: Members Posts: 214 Joined: 1-June 04 From: Greenwood, SC Member No.: 2,137 Region Association: None ![]() |
First check your wiring connections and clean them all! Then go to walmart or auto parts store and buy a 6 gauge wire or heaver and run the wire from the battery ground to the starter flange(clean it with a wire brush or sandpaper first). Also clean your trans ground! You can also put a thin gasket between the starter and the trans to cut down heat transfer, but you will need the ground!
Take Care Bill |
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
I really do wonder how many "hot start kits" have been installed on teeners that did not need it.
That is to say, that , there were other electrical connection issues that when corrected make the HSK, unneeded.{is that a word?} I also wonder how many "vaporlock problems" are also actually some other problem. John P.S. I have one in the first car I bought, the 75' (footer for Joe O (IMG:http://www.914world.com/bbs2/html/emoticons/pissoff.gif)) car, as directed, to be installed by me. (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Bill, I am looking at your signature and thinking you should get a couple more 914's. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) If your ever in the Marysville area, look me up. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) |
dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
hehe...Bill (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) been meaning to call you up about the progress of the engine. I might as well tell you here. It's in the car, everything is hooked up, it'll crank over, but im not getting it to fire up. Were the fuel injectors good to begin with? And what's the condition of the alternator? i replaced it w/ mines. Oh and what's the condition on the distributor?
Lo-Fi Version | Time is now: 17th June 2024 - 10:55 AM |
