R trailing arm assembly, How to? |
914werke |
Nov 3 2005, 06:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,142 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yes I did do a search (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif)
Can some one describe the process by which you "PULL" the hub into new bearings. Why pull rather than use a press? |
SirAndy |
Nov 4 2005, 02:49 AM
Resident German Group: Admin Posts: 41,680 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i used a press, worked just fine ... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Andy |
DNHunt |
Nov 4 2005, 08:25 AM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Rich
I heated the arms in the oven, got on the oven mits grabbed one arm and ran like hell for the garage. I froze the bearings. I went back and grabbed the bearings and dropped them in the arms. One side needed a bit of persuassion. I drew the stub axle through the bearing with washers and the big nut as I remember. Been a while. As I remember, I had an uncomfortable feeling in my bowels cause I was worried about ruining the bearings. Dave |
mightyohm |
Nov 4 2005, 11:06 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
The reason you pull them in is because you need to support the backside of the bearing, otherwise it will fall apart on you.
This is how you set it up: nut - big washer - bearing - hub - big washer - nut and threaded rod thru the whole thing. There is a good pic on Pelican. |
Lo-Fi Version | Time is now: 10th June 2024 - 04:00 PM |
