Clutch Adjustment, My clutch cable....how does it work? |
ehick72 |
Nov 7 2005, 09:23 AM
Member Group: Members Posts: 108 Joined: 28-December 04 From: Austin, Texas Member No.: 3,356 |
I just replaced my clutch, flywheel, and throwout bearing. It works great but I have to push the clutch all the way to the floor to be able to shift. The pelican article says "To make the clutch grab high on the clutch pedal, loosen the screw on the clutch cable.". That doesn't make sense to me. Anyway how do I adjust this thing?
Eric |
Dr. Roger |
Nov 7 2005, 10:25 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I noted you comment on my calendar thread so i thought i'd help out a little here. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) first thing: tighten the nut/adjuster on the end of your cable to bring the pedal freeplay to about 3/4". this should also bring the clutch engagement point to about 2/3's to 3/4 out on the pedal. experiment if you have to. that's what i ended up doing. i also noticed that with my new clutch cable, it had a certain stretch when being broken in and required adjustment after the first 50 miles of city driving.... also: there is a known issue with clutch tubes corroding at several points inside the shift tunnel which reduces clutch action. i havn't checked mine because it seems to engage just fine but you should be aware of it incase of any weird anomalies in yours... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) hope this helps. cheers, Roger |
Marlow |
Nov 7 2005, 10:30 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
You adjust the cable at the transmission end. There is a threaded portion at the end of the clutch cable where it attaches to the fork. Tightening the nuts there (there should be two, one for adjustment and the other as a locknut) will bring the clutch action towards the top of the pedal. After adjusting you should have about 1/2"- 3/4" of free play when you PULL on the clutch pedal (most cars you check freeplay by pushing on the pedal).
SirAndy |
Nov 7 2005, 11:32 AM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if you back off the (double!) 11mm nuts on the transmission end of the clutch cable, you're effectively making the cable *longer*, thus moving the point on your pedal where the clutch engages *up* towards you ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy PS: don't forget to tighten the double nuts when you're done ... |
Lo-Fi Version | Time is now: 1st June 2024 - 03:09 PM |
