> Kill Switch
bd1308
post Nov 7 2005, 06:42 PM
Sir Post-a-lot
okay, I know about the grounding points issue to stopping an engine cold in it's tracks.
but the downside is heating up that coil and having it blow up. I have points now (pertronix would have obvious problems with this).
does anybody know (i cant read wiring diagrams yet) which fuse trace and wire powers the coil? I know its unfused, so I guess I answered my own question...my gut feeling is that the only way to get to it is through the engine bay. But I could in therory put a kill switch in there.....
any thoughts?
b
Replies(1 - 19)
Aaron Cox
post Nov 7 2005, 06:44 PM
Professional Lawn Dart
you think someone is going to steal your car?
just pull the plug wire off your coil before you leave it (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Rider914
post Nov 7 2005, 06:46 PM
Switch the fuel pump if it is injected.
bd1308
post Nov 7 2005, 06:49 PM
Sir Post-a-lot
its carb'd.
i could do the fuel pump, give em a hundred feet till the fuel in the bowls runs out. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
could unplug the coil.
i dunno. any other ideas?
b
Dr. Roger
A bat out of hell.
Dude,
just run a wire from the neg terminal of the coil to a switch skillfully placed somewhere outof sight. then from the other terminal of the switch grounded to the body.
Walla'. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Suppose you could trace that green power wire from the ignition switch... Or was it black? (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
scotty b
post Nov 7 2005, 06:58 PM
rust free you say ?
(IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Killswitch?????
ENGAGE! (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif)
bd1308
post Nov 7 2005, 07:00 PM
Sir Post-a-lot
QUOTE (rogergrubb @ Nov 7 2005, 06:49 PM)
Dude,
but if the killswitch is engaged and the thief tries to dick with my car, starting and starting it....
the coil heat up and BLAMO! hot oil all over everything.
b
jd74914
post Nov 7 2005, 07:06 PM
Its alive
So, please tell us WHY anyone would want to steal your car? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
In any case, a kill switch is just something else to worry about. If you are that worried pull off the coil plug wire like aaron said
bd1308
post Nov 7 2005, 07:09 PM
Sir Post-a-lot
someday my 914 will look good.
b
jd74914
post Nov 7 2005, 07:25 PM
Its alive
joking BTW, but i still don't know why you wouldn't just unplug the coil, easiest to do, and it follows the KISS principle which means it is one less thing to worry about (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Aaron Cox
post Nov 7 2005, 07:50 PM
QUOTE (jd74914 @ Nov 7 2005, 06:25 PM)
werd (IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Mueller
post Nov 7 2005, 07:53 PM
914 Freak!
the proper use of the kill switch is remove all power from the battery to the rest of the car........
for your application, you could just get a toggle switch and wire it in series with the + of coil....
bd1308
Sir Post-a-lot
yep.
b
Flat VW
post Nov 7 2005, 07:56 PM
Illegal Soapbox Derby Racecar
QUOTE (jd74914 @ Nov 7 2005, 05:06 PM)
for the tools and valuable teener' parts in the trunk. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
John
r_towle
post Nov 7 2005, 07:57 PM
Custom Member
my race car had a simple 150amp 2000 amp surge kill switch in the negative battery line.
Basic to install, and you could either hide in the engine bay, or put it in the trunk
switch
Rich
Aaron Cox
"valuable Teener part" Oxymoron
scotty b
post Nov 7 2005, 07:58 PM
rust free you say ?
(IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) Why not just take the key out of the ignition?? (IMG:http://www.914world.com/bbs2/html/emoticons/051103-stupid4.gif)
effutuo101
post Nov 7 2005, 08:05 PM
I have a Bosch battery isolation switch on my car. I just moved it from behind the sail into the cab. It is steel and lasts about 1000 times longer then the cheap plastic one at your local parts house. I had one of the original Porsche switches, but it got swiped. If you put in a battery cut off, I believe that you have to cut off the + side of the battery. I moved to a rainy place, and decided to put the switch out of the elements.
Aaron Cox
post Nov 7 2005, 08:07 PM
like this chris?
(IMG:http://i1.ebayimg.com/01/i/04/ca/a9/1c_1_b.JPG)
i need one.... eric shea sold 2 for 30 bucks a piece or somehting a year ago.....
this choad wants 120 for it lol
Allan
post Nov 7 2005, 08:09 PM
Teenerless Weenie
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
- Lo-Fi Version Time is now: 16th June 2024 - 09:33 PM
