> What should be attached to this?
Buckeye '73
post Nov 10 2005, 07:22 PM
This is the passenger speaker.
Is the blue thing in the bottom of the picture a ground?
What was originally hooked up to it?
Thanks,
Bryce
Replies(1 - 7)
Aaron Cox
post Nov 10 2005, 07:25 PM
Professional Tinkerer
not stock. someone tried to use it as a ground it appears
bondo
post Nov 10 2005, 07:27 PM
QUOTE (Aaron Cox @ Nov 10 2005, 06:25 PM)
Yup.. bad choice too. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Cap'n Krusty
post Nov 10 2005, 07:28 PM
Cap'n Krusty
Some DPO used the speaker box screw as a ground for some unknown electrical device. Poor choice of a ground point, el cheapo amateur connector, poorly crimped; a good sign that there may be more problems under the dash. The Cap'n
Buckeye '73
post Nov 10 2005, 07:35 PM
Uh... Yeah....
No turn signals or horn...
Apparently there was some re-wiring done. (Note the new bus fuses in this picture.) (Also, the stupid SO% didn't have the sense to replace the fuse cover.... I spend 5 mins picking up fuses every morning...)
Hammy
post Nov 10 2005, 07:43 PM
mr. Wonderful
For the horn, slowly twist off the rubber horn pad and check the wire in there, your horn ground might be disconnected somehow. Mine was.
jd74914
post Nov 10 2005, 09:48 PM
Its alive
if the spring on the horn connection was pushed out of the way it won't work. BTW, i've only seen that happen on cars which someone messed with the steering wheel (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Elliot_Cannon
post Nov 10 2005, 11:19 PM
Group: Retired Members
QUOTE (Buckeye '73 @ Nov 10 2005, 06:35 PM)
Uh... Yeah....
Check resources, parts and products for some great after-market fuse blocks.
Cheers, Elliot
- Lo-Fi Version Time is now: 15th April 2026 - 08:02 AM
