94teener2 |
Newbie ![]() Group: Members Posts: 40 Joined: 2-October 05 From: livermore,ca Member No.: 4,903 ![]() |
Anybody know what the correct tube dia. and length would be for headers for a 1.7 used for club racing. Got the tools, got the time and a low budget. Better yet, any solidworks files out there. thanks andy |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
most use 1 1/2" diameter tubing...chances of someone having a CAD file is pretty darn slim.....
you should be able to reverse engineer it just by looking at pictures and scaling it up.....with a motor in front of you, you already have known dimensions to start off with. here is European Racing header (minus the stub pipes) (IMG:http://www.914world.com/bbs2/uploads/post-2-1051741143.jpg) |
Triaddave |
Member ![]() ![]() Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 ![]() |
i have built many headers. it may not be as easy as it looks. to get the nice, clean bends in the pipe, i use a mandrel bender. to do that, you need a pattern to get the proper angles. i also have the flanges laser cut from 5/16 steel. i have a jig to asure a proper fit to the car. bolt the flanges tight as well as the pipe to make sure nothing moves when you put the welds to it. good luck...
Mueller |
have you watched Rn Covells video on tube fabrication?
pretty darn neat, I have/had a copy someplace, just watched it a few months ago... metal working videos to buy this site has it for rent |
Lo-Fi Version | Time is now: 23rd September 2025 - 12:55 AM |
