oil pressure sender question, quick help :) |
Aaron Cox |
Nov 12 2005, 09:59 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
ok. so i currently have a 5 bar (80 PSI) dual sender on my motor.
i have a 904 gauge with a 150 PSI range (10 bar) will
from pelican work with 150 PSI 911 gauge insert? |
goose2 |
Nov 12 2005, 10:11 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
it should...the Pelican guys should be able to tell you for certain
Aaron Cox |
Nov 12 2005, 10:14 PM
it will work with the pressure side of this gauge? (or pressure insert for that matter)
(IMG:http://www.carquip.com/parts/911/elec/graphix/tcombi.jpg) cool. got an order to place at Pelican soon.... ill call glenn sager (a914luvr) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
jim_hoyland |
Nov 12 2005, 10:34 PM
Get that VIN ? Group: Members Posts: 9,318 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Isn't that what I just did ?
Installed the 10m bar sender on the 904; pressure gauge works. |
Aaron Cox |
Nov 12 2005, 10:40 PM
just double checking jimbo. thanks bud AA |
ein 6er |
Nov 12 2005, 10:49 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
i have a 904 gauge also, and i need the correct duel sender. how do you know what PSI your gauge is? what is the part # of your gauge?
doug |
Aaron Cox |
Nov 13 2005, 10:07 AM
if it is the 1 - 2 - 3 - 4 - 5 that is in BAR or (80 psi) the one in my gauge (IMG:http://www.carquip.com/parts/911/elec/graphix/tcombi.jpg) is 140 psi, or 10 bar.... |
ein 6er |
Nov 13 2005, 02:44 PM
thanks aaron!!
i get confused looking at this list of matching gauges and senders. it doesn't show a dual sender. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:23 AM |
