guiltless |
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-August 05 From: Dana Point Ca Member No.: 4,552 ![]() |
So I am doing a Suby conversion for my teener and I am still trying to figure out how much power to shoot for.
The car is basically going to be a barely streetable track car. I am not building it for comfort but performance and if I can make it a little comfortable in the process I will. Here's a bit of what I am planning: -Sheridan standard kit with 10" wheels under the rear for plenty of traction -All the suspension and brake mods necessary for a high hp racer -Roll cage I think you all get the point. Basically I can get 300hp for around $3500 or 450hp for around $6000+ (at the crank) Is the car even drivable with 450hp?(IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) I have experience with high hp cars so I can handle it, but i have never driven a high hp teener and don't really know what to expect. What do you guys think? What are your experiences? |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
what trans?
shoot... have fun. your money. 450 baby |
guiltless |
I will probably end up with the STI 6-speed. I really want a 5 speed, but it ends up being REALLY expensive, at least from what I have found. |
WRX914 |
2.5 WRX STI hybrid powered beast ![]() ![]() ![]() Group: Members Posts: 782 Joined: 16-September 04 From: Las Vegas, NV Member No.: 2,771 Region Association: Southwest Region ![]() |
Hooray! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Glad to see another Suby convert! |
Aaron Cox |
is your name chris?
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
it really depends on the motor.....a 450hp Chevy small block might be more "friendly" than a high-strung 450hp Suby motor... if it's just on/off with that kind of power, not too much fun or easy to drive...... but like Aaron mentioned, it's your money..let's go all out and go for the 450hp motor (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
ewdysar |
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 ![]() |
After riding with Scott of Renegade Hybrids in his 500hp 914 "The Peel", I would say that 450 is not too much... (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
I think that Scott's car fit that description, there are still photos at www.renegadehybrids.com under cars for sale even though they sold it. I posted a small video of the Peel in action at one of the Mullholland runs a while back. You should be able to find the video link using the search function. Eric |
guiltless |
Well... I think it may be settled then.
In the immortal words of Tim "The Tool Man" Taylor... "More Power!!!" |
OMB_Godfather |
Newbie ![]() Group: Members Posts: 49 Joined: 19-September 05 From: Bakersfield, CA Member No.: 4,823 ![]() |
I read another topic on converting the suby tranny for rear wheel drive and the general consensus from the parts manufacturers was that only the 5 speed could be converted and that parts still weretn available for the sti 6 speed yet. Has this changed? |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
I sold a SB Chev 914 with 415 horse. It was fast, ask Kevin Powers(pansy boy). One thing that this car had were super brakes. Brembo fronts. For the money you can't go wrong with a SBC.
CCLINICOULDHAVEHADAV8 |
guiltless |
From what I understand the conversion is not all that difficult. To put it crudely: Disconnect the rear electronic clutch, hack off the output shaft, and seal up the rear of the tranny. I have a few Suby tuners who are willing to help me out with the process once I get the cash together so we shall see. I would love to have a 5-speed that is strong enough, but all the suby guys are telling me that it is super expensive to strengthen the 5-speed. |
banksyinoz |
finally getting back into it ![]() ![]() Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand ![]() |
when i contacted the guys that do the blanking kit for the awd suby box they said that it was mainly a matter of the number of splines on the shaft with the auto and the six speed and that they havent done one as yet, from what i can gather the blanking plate may be the same though(but how hard would that be to make) the shaft is the problem.
300 hp would be more reliable but if you want all the goodies go 2.5 twin cam (new sti) or just get the stroker crank etc to build a 2.5 add 30 psi and hang on to the 500+hp at the crank, with the six speed you will be changing gears flat out but be havin heaps of fun (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) Attached image(s) ![]() |
guiltless |
So here is the next question.
How much power is actually usable with 10" wheels in the back? I don't want to be smelling rubber every time I touch the throttle, I want to actually put the power to the ground. I don't mind some wheelspin, just not a ton. I want to build a car that is truly racable, not JUST balls out fast. Trust me, if 450 is usable then I will be the happiest man alive. |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,525 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.” Mark Donahue |
Mueller |
have you seen a torque curve for THAT motor??? you cannot compare a 450suby to a 450chevy V8..the torque curve should be totally different you don't raceable, you want tractable...you don't want a motor that is like a light switch, on/off |
banksyinoz |
(IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) thats what im talkin about yeah seriously though with the 2.5 and a good ball bearing turbo setup to make boost early , the revrange will be good for both traction (you can also stage the boost)and your engine will thank you for not revving the (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) out of it all the time on my ej20t i have a gt28, it makes boost very early hence giving better control well thats my line of reasoning anyhow (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Attached image(s) ![]() |
okieflyr |
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States ![]() |
Having owned and auto-x'ed an STI for 2 years, (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) I'd say that even in stock power trim the car could be a real rocket.
My own experience with the gear ratios of the six speed is that It could have been faster with a properly spaced 5 speed. I often found myself "jumping" past gears to move along in traffic, as the torque was more than enough to move that heavy car! The gearbox is very tough, and I'd use one if I could, but there is ALOT of shifting involved. Kevin |
Lo-Fi Version | Time is now: 16th June 2024 - 06:58 PM |
