SS HE's, converting 1.7 to 2.0 |
STL914 |
Nov 17 2005, 03:00 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
OK, my car is to be repainted next spring if all goes well. I already have the mud guards and chrome curb feelers waiting to be installed. (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif)
I am also considering adding either a Triad West exhaust or a modified 2.0 OEM muffler with cookie cutter megaphones to the car. My problem is that I have a set of 1.7 SS He's on the car, even though the motor is a 2.2 liter 4 cylinder. The Triad muffler, as well as the 2.0 muffler, will only fit the 2.0 HE's. Is it possible to convert a set of 1.7 SS heat exchangers into a 2.0 system? Has anyone done this? Oh, I lied about the mud guards and curb feelers! |
Mueller |
Nov 17 2005, 03:04 PM
if you can cut and weld, then yes, you can change the rear mounting configuration to resemble the 2.0 h/e's
it might be easier to modify the inlets of the muffler instead......that is what I would do.... |
lagunero |
Nov 17 2005, 04:48 PM
Donkey Member Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
Dave at Triad is a great guy to deal with. Maybe a call and he can fab them to fit the 1.7. I Don't know if it's possible and I assume that they're not made because most seeking a Triad are most likely to own a 2.0 motor. There was a post on a recent thread that claimed 1.7 SS HE had a larger ID than a stock 2.0 HE. If so I'd definately contact Dave. Good luck.
Mueller |
Nov 17 2005, 05:20 PM
Same ID....people need to edit thier posts when incorrect.... |
r_towle |
Nov 17 2005, 05:26 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
so,,,is it a mythe that the 2.0 liter ones flow better???
There is a bend at the end, yes, but its very smooth... I measured them after someone said that the 2.o liter ones were bigger and I found them to be the same size...but then I questioned if I had 2.0 liter ones of some other ones...I have the 1.7 ones on the car... Please bust this myth....it will save me alot of un needed work if I can just keep the ones I have, braket and muffler too. Rich |
Bleyseng |
Nov 17 2005, 06:48 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
SSI HE are the same ID!! 1.7 ones have the bends in them so you lose "alittle" with that.
I have measured the stock 1.7 and 2.0L HE's years ago IIRC that they are different. |
rhodyguy |
Nov 18 2005, 09:38 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
trivial but on topic. the he to muffler gaskets have different bolt hole spacing on the 2.0 style as compared to the 1.7/1.8= the flanges will not mate up properly. i think the piping "kick up" on the 1.7/1.8 could lead to some interference issues with the heat shield on the bottom of the rear trunk.
k |
Lo-Fi Version | Time is now: 9th June 2024 - 06:47 AM |
