DAPO or factory, Throttle tube liner |
Joe Ricard |
Nov 22 2005, 06:06 AM
So the throttle cable decides to stick yesterday morning. What the %^$%&$$
So didn't take it to work. Got home last night and started looking. Decided that the cable was the culprit not the CB linkage. Tried pulling string through as old cable came out. Turns out the cable end won't got through the tube. More *&^^%^** and ended up breaking the end off the cable as I pulled. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) There is a plastic liner indie the tube that wouldn't let it pass. White liner is pretty stuck but managed to push some of it up the tube but not far enough to grab from front of tunnel. About then my fingers were numb and it got real cold out AND dark. So I am deleting the liner I guess, and applying a good coat of grease to the cable. IF the liner is supposedto be there How the hell do you get the cable through? |
bd1308 |
Nov 22 2005, 09:50 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
did you cut the other end off?
as-is, the cable wont move through the sheath or the liner insert. but if you cut it and it STILL wont move, time for a new cable. b |
Root_Werks |
Nov 22 2005, 10:15 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That liner comes on the cable. it's not part of the car, remove it. When you buy a new cable, it should have that plastic liner on it. If it doesn't, go buy one that does.
What happened is your cable over time started to break the little threads one by one. There is enough of them in there now they have bunched up and jammed in your tube. Push everything out however you can, get the tube free and clear. Slip in a new cable WITH a plastic cover over the cable part of it and all will be well again. Seen it a dozen times. Someone will come in with a sticking throttle..... |
URY914 |
Nov 22 2005, 10:25 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Easy fix is to buy a new cable.
Get the "Terry Cable" from Pelican. |
Aaron Cox |
Nov 22 2005, 10:33 AM
dont lube your new cable.....
Joe Ricard |
Yea, got a new cable. Thanks for the insight Britt. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Just a PITA to get plastic out. went out and bought an extra long chopstick. Well actually a wooden dowel rod to push plastic out. New Terry cable don't have plastic. |
bd1308 |
Joe Ricard |
Nov 22 2005, 10:46 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif) That's pretty funny (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Cheers! |
Root_Werks |
Nov 22 2005, 11:45 AM
Just FYI - if your new cable doesn't have the plastic lining the metal cable will rub against the metal tube EVERY TIME you work the gas pedal which is A LOT. You'll be fishing out another cable mess in another year only this time it might be worse as the cable might have cut it's way into the side of the tube. That is what the plastic protects against.
I had a brand new cable without plastic tube on it and threw it away. They are nothing but trouble. Toss yours and go get the correct part. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
maf914 |
Nov 22 2005, 12:18 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
After you complete this task, you can stick the chopstick into one of your sparkplug holes. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) What a thread that one was! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Joe Ricard |
Nov 22 2005, 01:25 PM
I'm going to figure sumpin out. car is stuck outside till I get it fixed. So I might get it rigged to drive it up the block and put away.
Yea the great chopstick thread what a hoot. (IMG:http://www.914world.com/bbs2/html/emoticons/poke.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:21 PM |
