dheinz |
cross member ![]() ![]() Group: Members Posts: 122 Joined: 7-August 03 From: Pittsburgh, PA Member No.: 995 ![]() |
Do 914/6 and 914/4 use the same rear brake pads?
Thanks in advance |
joea9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None ![]() |
Yes ... the pistons are bigger on the 914/6
sixerdon |
Member ![]() ![]() Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 ![]() |
I beg to disagree. I have original sixes and a four. The sixes are bigger.
Don |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,156 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Don is correct. The 914/6 rear uses pads the same size as the 914/4 front. The pds are not the exact same as the fronts though due to the two differnt size pin holes on the rear. They are as thick as the early 914/4 front. Almost the same pads as the 911 rear except for the pin holes.
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) At least in the past there have been online places that sold pads that were the wrong (914-4) ones. I think a database got screwed up somewhere in the past. I just buy front 914-4 (early) pads and drill half the holes bigger. The late 914 pads don't work as the calipers were redesigned to use thicker pads to make them last longer. |
Cap'n Krusty |
Early 911s used smaller rear calipers and pads, the same size as 914/4s, but with symetrical holes for the pins. See, blanket statements can often be misleading. The Cap'n |
Lo-Fi Version | Time is now: 15th June 2024 - 06:57 PM |
