tiim5 |
Member ![]() ![]() Group: Members Posts: 86 Joined: 13-March 04 From: Menlo Park CA Member No.: 1,791 ![]() |
The heater blower in the engine compartment of my 73' 1.7 has a single inlet for the hoses from H/E's . I have seen these with two inlets one from each side of the motor.
The passenger side on my car has been capped by po. There is one, not connected because torn, hose from the drivers side that looks like it would be the only source from the h/e's to the blower motor. Is this a stock set up? Was there a tee fitting of some sort to remedy this. Do I have a very strange blower motor installed? Thanks. |
McMark |
Early cars (70-72) had the double outlet housing fan.
Mid cars (73-74) had a single outlet housing fan with a single hose to the drivers side and a stock cap on the passengers side. (This is you. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) ) Late cars (75-76) had the same single outlet fan with a splitter and hoses to both sides of the motor. Heating air comes not only from the auxiliary fan you're seeing, but also from a small amount of air coming from the engine cooling fan. You can get some heat without an aux fan, but it's a small amount compared to the with the aux fan. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Hi,
Could you please show a pic of the splitter hose arrangement....we will need more heat... Rich |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
wait so my heater blower only blows to the driver's side?
Oliver |
Member ![]() ![]() Group: Members Posts: 66 Joined: 7-May 05 From: Portland, Or Member No.: 4,038 ![]() |
Yes please post a pic or two of how the hose system work's...
It would be real nice if it was for a 1.8l 1974 914... :wink: It's cold and the carb will be rebuilt... (IMG:http://www.914world.com/bbs2/html/emoticons/dead horse.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) Attached image(s) ![]() |
McMark |
I can't find any pictures in the factory manuals. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
The splitter just slides into the end of the fan. Hopefully someone else can snap a shot. |
STL914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest ![]() |
This splitter has been posted on eBay recently. Do a search to see if it's still there. There is currently a blower with dual outlets on eBay:
http://cgi.ebay.com/ebaymotors/Porsche-914...ZWDVWQQtcZphoto I can post a picture later today of the splitter I removed from my 74. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
r_towle |
thank you for that pic.
tiim5 |
Thanks Mark, as usual, your knowledge is amazing!
STL914 |
SLITS beat me to posting the picture, but at least I can provide a part number that's on mine: 461261831A and it's a VW part number. So check your local VW parts department or bug shop.
MartyYeoman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,520 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California ![]() ![]() |
Any comments on which if these setups works best and why?? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
SLITS |
It has been said that the blower is not powerful enough to blow thru two hoses, so the "double" blower was dropped in favor of the single.
That said, they went on to produce the splitter for a single outlet..... You decide..........they both work |
STL914 |
For those who may be interested, this is the eBay link to a heater update kit; splitter and hose:
http://cgi.ebay.com/ebaymotors/PORSCHE-914...sspagenameZWD1V |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
What works best would be two single blowers....
More total cfm... That said, I am in need of a double blower for a certain project... (v8 heater, using an oil cooler up front... ) Hmm ebay eh? |
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
I find if I roll the windows down a bit the heat seem to "flow" better.
I was also reminded, one evening, recently, that the heat really works well when the top is off. (IMG:http://www.914world.com/bbs2/html/emoticons/blowtorch.gif) But then again, my number one passenger (my wife Laurie) thinks 60 degrees F. is cold, a southern Arizona girl, phurshur....... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) YMMV John (IMG:http://www.914world.com/bbs2/html/emoticons/blowtorch.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 11:04 AM |
