winter project (maybe), i must be crazy |
double-a |
Nov 30 2005, 11:04 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
i've got a few months to kill until i need to get the bodywork and paint done on the car, so i got to thinking... what do 4-lug mahles look like all polished up? i've got an unshod spare, why not find out?
now i know why i haven't seen many polished mahles. here's what a stock wheel looks like with 30 years of crud, curb rash and two or three coats of paint: Attached image(s) |
double-a |
Nov 30 2005, 11:06 PM
20 (or so) hours later, voila.
Attached image(s) |
double-a |
vive la difference.
Attached image(s) |
double-a |
Nov 30 2005, 11:16 PM
mahles are beset with the most wonderful array of pits and casting flaws. sanding the thing down to the point where i could think about polishing took 10 hours or so. still don't know if i'll do the other four wheels, what a job. my fingers are numb, and bleeding.
1. strip paint and grime from wheel 2. 60 grit to get pits and other casting flaws removed 3. dremel 120 grit sanding drum for eight holes, lots of work 4. 100 grit 5. 220 grit 6. 400 grit 7. 800 grit 8. 1000 grit, wet sand x2 9. dremel buffing attachments of various sizes 10. mothers aluminum polish x3 those ribs make it difficult to get all the crud out, so the thing isn't perfect by any means. it looks good from 5 feet, best i can do with what i've got. i think i'd be crazy to do the other four though, it's a lot of work for a cheapo wheel (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ~a |
jonwatts |
Nov 30 2005, 11:21 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
It's much less of a cheapo wheel now that it's polished.
So based on your experience would you pay someone else approximately $100 / wheel to do it? |
double-a |
Nov 30 2005, 11:30 PM
where do i send the check? it doesn't look terrible, but anyone else would probably do a better job than me anyway, i've never polished anything i my life. until now, that is.
~a |
thomasotten |
Dec 1 2005, 01:10 AM
Senior Member Group: Members Posts: 1,547 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Looks good!
mikey |
Dec 1 2005, 01:26 AM
Member Group: Members Posts: 423 Joined: 30-January 03 From: San Francisco Member No.: 214 Region Association: None |
Looks very nice after the polishing.
Are the 4-lug Mahles aluminum or magnesium? I've been told by a polisher that magnesium needs to be painted because it tarnishes and gets ugly and blotchy if left unpainted. I'll be using a set of 5-lug magnesium Mahles (Gasburners) on my -6, and wonder if I should attempt this. |
SLITS |
Dec 1 2005, 05:21 AM
Supposedly... Pedrinis = Cast Aluminum Mahles = Pressure Cast Aluminum Fuchs = Forged Aluminum Your results may vary...................... |
MecGen |
Dec 1 2005, 05:45 AM
8 Easy Steps Group: Members Posts: 848 Joined: 8-January 05 From: Laval, Canada Member No.: 3,421 |
Great Job Man (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Yes I have been there and done that.... blisters. The wheel shops in my area charge 100$ for a refinish, 175$ for a buff. X5 it gets pricey. I have a blast cabbin, and it still takes at least an hour to clean a rim. The big boys have a more automated set-up.... On my Monte SS, I stayed with sandblast and paint. Too lazy. Hands down your wheel is greatly improved, and even if you stop at just the spare tire, its a cool personal touch for your car! +Karma (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
double-a |
Dec 1 2005, 08:57 AM
what's the difference between forged, cast and pressure cast? how are the creation processes different? i have noticed that the fuchs always look very smooth, even after 30 years. these wheels have gobs of casting crud, which adds many hours of labor. i have never seen the 5-lug gasburners polished, but i bet it looks incredible. thanks for the kudos guys. a couple more compliments and i may even do the rest (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) one question though: can these wheels be blasted smooth? ~a |
mudfoot76 |
Dec 1 2005, 09:06 AM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
Explanation of different metal forming techniques
Section II has some stuff about casting. Hope this helps (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
SLITS |
Dec 1 2005, 09:17 AM
Cast - - - good strength, grainy (porous) finish, cheapest method Pressure cast - - - better strength, less grainy finish, Forged - - - highest strength, fine grain (smooth) finish, most expensive It all revolves around the cost to make the part, the finish and strength desired..IMO. |
double-a |
Dec 1 2005, 09:54 AM
ok, might as well do the other four. i'll need more tools of course (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
dremel contour sander ~a |
Lo-Fi Version | Time is now: 10th June 2024 - 07:26 PM |
