> Want to pain transaxle, What paint to use?, transaxle painting.
pnewman
post Dec 1 2005, 12:34 PM
I have pulled my transaxle and I am going to change all of the seals and do a first gear job on it. I was thinking of painting it while out and clean.
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Should I or shouldn't I? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
If I should do I need to use a high heat engine paint because of the close proximity to the exhaust? Thanks, Pete
Replies(1 - 19)
WRX914
post Dec 1 2005, 03:13 PM
2.5 WRX STI hybrid powered beast
The best way is to have it powdercoated...
Katmanken
post Dec 1 2005, 04:59 PM
You haven't seen me if anybody asks...
The thing I don't like with powdercoating is it is a 2 stage process...
1. Apply the powder.
2. Bake in oven to melt the powder.
I like 1 ok, it's step number 2 that I won't do with a whole tranny and seals.
So to powdercoat right, it's a COMPLETE tranny dissasembly...
Ken
Andyrew
post Dec 1 2005, 05:06 PM
Spooling.... Please wait
Standard high temp paint would work...
I doubt it gets over 200 degrees on any 1 point.
jsteele22
post Dec 1 2005, 06:47 PM
Probably the best way is to hook it up to a massively built V8, and use something w/ a lot of sand. Pop the clutch at redline. Or did you mean paint the transaxle ?
Aaron Cox
post Dec 1 2005, 08:20 PM
Professional Lawn Dart
please dont paint your trans.
just clean it up. ive seen a few UGLY trannies... paint flaking off etc.
ill take magnesium look anyday.
my 2 cents
bd1308
post Dec 1 2005, 09:48 PM
Sir Post-a-lot
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
pnewman
post Dec 1 2005, 11:59 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) aah, dead kittens, hmmmmm. So if I paint this thing am I really gauranteed that got will kill some....hmmm. so how many kittens per oz. of krylon or rustoleum? Let's see! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
I just pressure washed it. I think I am going to try a brass drill attachment next! and then some clear or ?
jsteele22
post Dec 2 2005, 10:43 AM
QUOTE (bd1308 @ Dec 1 2005, 08:48 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif)
(and I like kittens....)
Gint
post Dec 2 2005, 06:21 PM
Mike Ginter
Didn't we do a thread just like this, just yesterday or the day before?
Or are all of these threads running into a massive blur and I've totally lost touch with reality?
bd1308
post Dec 2 2005, 06:23 PM
Sir Post-a-lot
QUOTE (Gint @ Dec 2 2005, 06:21 PM)
andy created us all...
i dont exist
[process finished]
soloracer
post Dec 2 2005, 06:52 PM
On a similar note, my magnesium 915 tranny looks like it sat outside near the ocean for about 1/2 of it's life. The input shaft and output flanges have a good coating of rust on them and the case has a "patina" that makes it look dull and grey. I'm worried that the input shaft may have to be replaced as the splines might be damaged. Is this a legitimate concern? Can the transmission case, flanges and input shaft be media blasted?
Katmanken
post Dec 2 2005, 10:40 PM
Um Soloracer...
The answer is it depends....
It depends on how much rust and how much power from the engine.
A lotta rust will pit the shaft. Pits can be crack propagators. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Surface rust- media blast or wire brush and ospho is another option.
Ken
Aaron Cox
post Dec 2 2005, 10:41 PM
im sure you could blast the case.... AFTER you dis-assemble it and mask off bearing races etc......
then make sure....very sure that no sand is left inside....
dmenche914
post Dec 4 2005, 09:15 PM
Much success and still good lookibng paint job after ten years using Rustoleum primer and then grey gloss top coat. no specail heat paint was needed. Cleaned the tranny real well first, lots of solvent and steelwool to clean it up. i did this with tranny fully assembled.
I think the tranny should be protected with paint or other coating cause the magnesium will corrode very easy if left bare( they usually get enough oil leaked on them to keep them corrosion free, but if you clean the underside often, you wont have that rust proofing oil film.
Good luck
pnewman
post Dec 7 2005, 02:46 PM
Thanks to all! I finished doing the first gear job and replacing all of the seals and o-rings etc. Now I have to make the decision. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
I pressure washed the trani when I first removed it from the car so as to have a clean transaxle to work on. Now that it is finished I thought that I would try to clean it a little better: i.e. with a brass wire wheel attachment to my 90 degree angled pneumatic grinder.
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) WOW!!!!!!!!!!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
It was like polishing a turd!
I think that I will do the entire transaxle now and then clear coat it!
Thanks to all for your support and inspiration!
Pete (IMG:http://www.914world.com/bbs2/html/emoticons/rocking nana.gif)
Lou W
post Dec 7 2005, 02:53 PM
Region Association: Spain
dmenche914 Posted on Dec 4 2005, 08:15 PM
Good luck
Do you have any pictures? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
pnewman
post Dec 7 2005, 09:31 PM
I'll take some pictures tommorrow or this weekened. Mid turd polishing. Next week when finished I'll shoot the pre-install pics and post them.
Thanks for the interest. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I just hope that the rustoleum clear holds up as well as your rusto- grey primer .... that I was considering! (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
Pete
pnewman
post Dec 11 2005, 10:22 AM
Well the transaxle is finished and ready to reinstall! I went over it with three different brass wire wheel attatchments for my pneumatic angle die grinder. and then taped it off and clear coated it.
I went with clear coat because the magnesium polished up quite nicely and I was also afraid of paint peeling later and looking like (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) !
Thanks for your input!
Dr. Roger
post Dec 11 2005, 01:30 PM
A bat out of hell.
QUOTE (dmenche914 @ Dec 4 2005, 08:15 PM)
Good luck
think i remember seeing a pic of yours almost a year ago?
looked awesome and probably helps maintaining cleanliness.
if i thought the coating slowed heat dissipation in any measurable amount i wouldnt do it. but i dont think it does. most of my bikes never had that stuff on the cooling fins but the 901 fins are primarily structural.
make 'er pretty and take pics. i'll prolly do the same thing before mine gets too gummed up too. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
- Lo-Fi Version Time is now: 31st July 2025 - 05:37 PM
