| LukeD |
Dec 2 2005, 03:02 PM
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
Ok, been neglecting this issue for a while so i decided to recruit my wife for some trouble shootting. Here are the symptoms.
Left and right blinkers front and back work fine. With Parking lights on - left blinker blinks a little slower but so does the left rear brake light. Right side works fine. With brakes applied - left blinker blinks real slowly and in the rear the outside marker and brake light alternate. Right side works fine. I have gone through the wiring for about 2 hours. Everything is wired correctly that I can tell. If I unplug the wire on pole 58 on the drivers LR then the blinkers work fine until I turn on my parking lights and I am back to square one. If I leave the wire off I have no parking lights LR. I do not know where to look next. They blink slowly so could it be a parking light ground issue? is this located by the relay board? Also, the poles on the LR brake housing do not match the Hayes manual. My housing has Poles ; First row closest to engine; 58, 54, RF - Second row closest to outside lens; L, I Manual only show 58, 54, 49L WTF? LukeD |
| Tobra |
Dec 2 2005, 03:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Mine had some of the symptoms you describe, that were cured by a new relay. It is located on the fuse block, used a VW unit for significantly less cost, here is the tale.Relay thread
Lo-Fi Version | Time is now: 1st May 2026 - 01:22 PM |
