L Jet Tuning, out of tune |
bernbomb914 |
Aug 20 2003, 12:44 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
Is there a way to adjust the FI for richness? My 1.8 runs rich at the bottom end and lean at the top end. Head temp goes over 450 when you pull a hill over 3000 rpm and runs rough under 2000 rpm. it stays around 300 when I keep it around 3000 on the freeway. what should I do? is there an adjustment?
Bernie (IMG:style_emoticons/default/confused24.gif) |
Mike D. |
Aug 20 2003, 01:01 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
You should check the air flow meter for movement. It sounds like it's not closing enough at idle and not open enough at high rpm. Or it may be moving fine, but the brushes on the sensor part not working properly.
Also not sure about the 1.8 but the 2.0 computer has a richness adjustment nob for idle setting. Also the 2.0 has a head temp sensor, and we sometimes add a resistor inline between the sensor and the computer that will richen the mixture at high rpms when the engine is hot. Again, not sure if the 1.8 has the same thing or works the same way if it does. -Mike D. |
fronkensteen1999 |
Aug 20 2003, 01:55 PM
Unregistered |
Dave_Darling |
Aug 20 2003, 03:04 PM
ChrisReale |
Aug 20 2003, 03:16 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Shit dude, 450 is way too hot.
Lo-Fi Version | Time is now: 3rd June 2024 - 01:09 AM |
