Noob question, /6 oil change |
Allan |
Dec 6 2005, 01:43 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
How?
Does a six have the same set-up as a four? Drain plug, sump plate & screen? Thanks... |
brant |
Dec 6 2005, 01:44 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Generally is is agreed that to change the oil you must undo one of the oil lines.
the one that gravity feeds from the tank to the suction (motor inlet) right on the motor oil cooler. brant |
smg914 |
Dec 6 2005, 02:56 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Yes, but instead of one nut in the center holding the sump plate on the six has 8 nuts holding it on. And of course the six has an oil tank that must be drained too. |
Root_Werks |
Dec 6 2005, 03:03 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
On that six, you can just pull the drain plug if you want or the plate. Take and loosen the brass line off the oil cooler and let the tank drain from that. remember it's brass to aluminum so don't overtighten.
DonTraver |
Dec 6 2005, 04:17 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
Use cardboard as splash guards, when you break the oil line, it just goes everywhere, and make sure the oil is hot, at least 140F, so try not to spash on you. Just a pia messy job.
Later, Don |
SLITS |
Dec 6 2005, 04:19 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Buy a suction pump and suck it out of the tank..................
MattR |
Dec 6 2005, 04:27 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Or you could hire aaron. |
Porsche Rescue |
Dec 6 2005, 04:33 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
You will get more than half of at least 10 quarts from the tank. Be sure to have a big pan. Probably get only 2-4 quarts from the case.
SLITS |
Dec 6 2005, 05:11 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) ZINGASLAPWHAP (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) |
Root_Werks |
Dec 6 2005, 05:26 PM
I think that holds almost 11 quarts with that tank? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Hot oil feels good on cold hands. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
brp914 |
Dec 6 2005, 09:26 PM
Unregistered |
dont trash the fittings by using arc joint pliers to separate the lines from the oil tank. buy the 36 mm oil line wrench. those lines are $$$, if not nla.
J P Stein |
Dec 6 2005, 09:34 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Golly....and to think what I do (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
I let her set for a couple-3 weeks. All the oil runs back thru the scavenge line & oil pump into the sump. Pull the plug, & out it all comes. I let it sit & drain for a week. I get 10+ quarts out. I haven't cracked open a line in years. |
smg914 |
Dec 7 2005, 12:03 AM
According to the owners manual, an oil and filter change on a stock 2 Liter 6 with the factory oil tank, takes 9.5 quarts of oil.
maxwelj |
Dec 7 2005, 02:40 AM
rebuilt member Group: Benefactors Posts: 278 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None |
To ease oil changes on mine, I had a tee with a brass ball valve welded into the metal ell on the lower end of the line from the oil tank. It is easily accessible from the wheel well, and has not ever come open by itself. Makes oil changes a snap. Yes, I know, it's not original....
bottomend |
Dec 7 2005, 03:59 AM
Member Group: Members Posts: 180 Joined: 27-August 05 From: LA,Ca Member No.: 4,683 |
10 Quarts! TEN QUARTS!!!!!!!!!! thats amazing... what is the change interval? Is it longer than normal?
sixnotfour |
Dec 7 2005, 06:14 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Aint that like watching grass grow (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) JP in CA. its nice enough even in winter to drive em. (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
Root_Werks |
Dec 7 2005, 09:15 AM
Allan's car has one of the larger than stock aluminum tanks. Holds roughly 11qts with a filter change. |
smg914 |
Dec 7 2005, 09:35 AM
I change mine once a year. I've put 21,000 miles on my six in the last 27 years. Thats about 750 miles a year. |
Racing916 |
Dec 7 2005, 09:40 AM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
I have read change the oil once every 5,000 miles in a six, I believe it was in the manual I read this.
brant |
Dec 7 2005, 10:02 AM
I'm running 19 quarts now... and changing it after every weekend of track use. ouch... mobil 1 ouch... |
Lo-Fi Version | Time is now: 10th June 2024 - 04:30 AM |
