six install tech info needed, running oil lines from tank...... |
pete-stevers |
Dec 9 2005, 12:34 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
i woul like to know which lines need to be run from the stock 914-6 oil tank ...
there are two lines in question the ones at the bottom of the tank...one inside the engine compartment. and secondly the one inside the fenderwell....which one goes where?? i have a feeling i don't want to make a mistake with this! thirdly the line from the from the engine mounted oil cooler...where does the oil go from here.... and forthly the line from the diver side of the engine...where should i run that line to??? thanks guys (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Trekkor |
Dec 9 2005, 12:46 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
No problem!
The lower fitting under the oil filter is oil return from the side of the engine case. ( passenger side under oil return tubes. ) The fitting in the fender well goes to the oil cooler mounted fitting on the motor. ( oil supply ) KT |
Porsche Rescue |
Dec 9 2005, 01:16 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
If this is a new conversion you will need to drill a hole for the line from the engine case (pass. side) in order to get it to the fitting on the tank (connection in the engine compartment)
Attached image(s) |
Porsche Rescue |
Dec 9 2005, 01:18 PM
Another
Attached image(s) |
IronHillRestorations |
Dec 9 2005, 06:12 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'm sure it works OK, but I wouldn't modify the hard oil line like the picture. I would cut it off before the 90 bend, and route the flex line over the engine mount. It's too low for my liking.
sixnotfour |
Dec 9 2005, 06:28 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Porsche Rescue |
Dec 9 2005, 07:43 PM
Now you tell me! I ain't gonna hit no big rocks on the AX course. And if I do, I know where to find the guy to fix it! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
pete-stevers |
Dec 10 2005, 12:01 AM
bump
davec |
Dec 10 2005, 12:10 AM
Member Group: Members Posts: 98 Joined: 11-February 03 From: Connecticut Member No.: 292 |
OK, when are you gonna ask the "is there gonna be enough cooling with the stock oil cooler" question? (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif)
J P Stein |
Dec 10 2005, 06:11 AM
The run, my way.
Attached thumbnail(s) |
J P Stein |
Dec 10 2005, 06:14 AM
Continuation....and older pic.
J P Stein |
Dec 10 2005, 06:15 AM
THE END
J P Stein |
Dec 10 2005, 06:20 AM
THE START... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Just found this. 9o deg pointed aft
Porsche Rescue |
Dec 10 2005, 09:43 AM
Hell, that's at least a half-inch higher than mine! I thought yours went over the top of the shift rod.
J P Stein |
Dec 10 2005, 11:51 AM
The bottom of the hose is about even with the bottom of the pan. Going over the bar is problematical. There's too much stuff in the way that the line could rub against....like brake lines. Stuff rubbing against braided line looses the battle.
East coaster |
Dec 10 2005, 03:14 PM
Senior Member Group: Members Posts: 1,691 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
Don't know if this will help..........but it can't hurt!
Attached image(s) |
Dec 10 2005, 06:00 PM
I've routed them over the top of the Johnson mount, using padded hose brackets, onto the big bolts that secure the mount to the firewall. It's a straight shot from the hole in the left side engine shelf all the way across the lower firewall.
J P Stein |
Dec 10 2005, 06:09 PM
Humm.....that would be doable. That would give the leaking oil a free shot to the ground rather than dripping on my pretty hose. I'll look at that when this motor scatters (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
davec |
Dec 10 2005, 11:18 PM
Danger, danger Will Robinson!!!! This is the picture from the 914-6 book that I originally used to hook up my first 2.0s six a few years back. As you can see, the diagram is backwards. Don't hook it up that way, you'll fry bearings. They do, however, make a cute screaming sound, right Mike D?.
J P Stein |
Dec 10 2005, 11:27 PM
The oil flow directions are right & to the right places....the tank is the problem....kinda backasswards....or is that assbackwards?
Can't hurt, eh? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:21 AM |
