Odd noise., Any ideas? |
fiid |
Dec 14 2005, 12:05 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
My car makes an odd noise during mild acceleration. It sounds kind of like a wheel rubbing - but it only seems to do it under mild acceleration. If I hoof it, or let it overun (or even just maintain speed) it seems to go away. It seems to be related to road speed and not engine speed.
I'm pretty sure all my bearings are tight. Front shocks are Bilstein casings so it shouldn't be the shock in the tube causing the problem. I bounced around on the car in different places to look for loose stuff but nothing apparent... Anyone have ideas for things to check? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
goose2 |
Dec 14 2005, 12:08 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
rear tire rubbing on fender lip? loose motor mount(s)?
Aaron Cox |
Dec 14 2005, 12:09 PM
i had a similar noise.... rear wheel bearing (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
fiid |
Dec 14 2005, 12:16 PM
I just changed the rear bearings, rotors, pads and e-brake cables. I'm a little suspicious of my CV joints. It's also possible that the hub bolts aren't torqued properly. My impact wrench is supposed to be good for 250lbs, so I whaled on them with that....?????
The engine does bounce a little over bumps (need a framing fix for that!), but I'm pretty sure it's bolted down. |
tat2dphreak |
Dec 14 2005, 02:28 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
my first though too... does it on some turns? |
Lo-Fi Version | Time is now: 1st June 2024 - 08:14 AM |
