Problems if I don't run the decel valve??? |
Mueller |
Feb 12 2003, 02:04 PM
Currently my D-jet 2.0 only has two of the three hoses hooked up on the Decel valve (two larger diameter that go to the plenum)...where does the third line go?
What are the ill effects of removing this all together to rule out vacuum leak sources while I fine tune the motor (don't worry Mike, I'll put it back (IMG:style_emoticons/default/smile.gif) ) |
mikerose |
Feb 12 2003, 02:19 PM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
Mike can I use the six to drive to the east coast next week (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif)
Brad Roberts |
Feb 12 2003, 02:22 PM
MikeD,
Your ballsy. Car hasnt ran in 10 years. I drove it 20 feet forward yesterday under its own power. Let me bleed the brakes and exercise the pistons and you can drive it. Heat even works. MikeM. I normally remove the decel valve. B |
airsix |
Feb 12 2003, 02:37 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Hey Mike, when I did my PEFI conversion I did away with the decel valve.
Effect has been possititve. The engine spools down much quicker when the throttle is closed. Shifting is much quicker now. Some might say that you could have stalling because the rpms will drop too fast. I haven't had that problem, but I'm also running more advance at idle than stock in combination with a restricted air-bleed port to pull idle down to 900. I still get stock idle speed but with much higher manifold vacuum, so it never stalls and pulls better off idle. I don't see any reason to keep the decel valve. -Ben |
Demick |
Feb 12 2003, 03:15 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
Only reason (besides emissions) to run the decel valve is if your valve guides are worn and your engine tends to smoke on overrun when hot. The decel valve will not let the intake vacuum get as high, reducing the amount of oil getting sucked by the valve guides on overrun.
Demick '74 2.0 |
efrenv |
Feb 12 2003, 03:49 PM
Newbie Group: Members Posts: 35 Joined: 11-February 03 From: Claremont, California Member No.: 297 |
Plugged the deceleration valve and hoses on mine, car runs o.k. ... knock on wood ... (IMG:style_emoticons/default/smile.gif)
Mainly for emissions (ref: Haynes Manual) Efren '76 2.0 |
Dave_Darling |
Feb 12 2003, 04:28 PM
The small hose goes to the manifold. One of the large hoses (doesn't matter which) goes to the air cleaner, and the other goes to the manifold.
Not a critical item, but I think they're reasonably nice to have. --DD |
Lo-Fi Version | Time is now: 11th June 2024 - 08:05 PM |
