Any Carb experts around?, or good hit men? |
Mike's2nd914 |
Aug 24 2003, 03:45 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
My 2.0 had the FI unceremoneously removed by a previous owner and a cheap no-name 2 barrel mounted in its place. It has been running OK but yesterday when I first cranked it, it did not want to idle. I was going to take it to run a few errands so I figured I had not been driving it enough lately so I took it anyway. Once it warmed up, it wanted to "idle" at about 4 grand. I could stab at the loud pedal and it made no difference, still 4 grand. I got it home and let it sit a while and cranked it again, same thing, 4 grand. (IMG:style_emoticons/default/headbang.gif)
Today, I sprayed the carb full of carb cleaner and let it sit a few minutes, not it wants to idle at 2 grand. Any ideas, suggestions, names of good hit men, etc? (IMG:style_emoticons/default/fighting19.gif) Thanks, Mike |
TheCabinetmaker |
Aug 24 2003, 03:55 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
sounds like a vacuum leak.
redshift |
Aug 24 2003, 04:17 PM
Have to ask..... have you looked at the t'rottle return spring? (and general state of the cable)
(IMG:style_emoticons/default/idea.gif) If it's a leak, it usually repeats the same symptom, then get's worse. M |
rhodyguy |
Aug 25 2003, 09:41 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
take off the filter top. open the throttle plates let go, they SHOULD snap back to close. bind in cable, stiff/ hard to operate shaft?
kevin |
Carl |
Aug 25 2003, 02:56 PM
Ummm ... what? Group: Members Posts: 781 Joined: 17-January 03 From: San Jose, CA Member No.: 163 Region Association: Northern California |
I misunderstood the original post. That probably is a vacuum leak - and a big one, too!
Carl |
Mike's2nd914 |
Aug 25 2003, 05:52 PM
Vacuum is likely it, dang thing doesn't have a vacuum hose on it that's not in pieces.
Lo-Fi Version | Time is now: 23rd May 2024 - 01:25 AM |
