GTS Rallye ST seats??, what's it take to make them fit? |
East coaster |
Dec 27 2005, 12:20 PM
Senior Member Group: Members Posts: 1,692 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
Is anyone running these particular seats? If so, what needs to be done as far a mounting brackets/mods??
I see that the LeMans seat is made for the 914, but I like Rallye ST better. (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) Edit: oops, almost forgot, will they fit with stock back pad?? |
Aaron Cox |
Dec 27 2005, 12:21 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
they indirectly make your car faster.... by lightening your wallet (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif)
JoeSharp |
Dec 27 2005, 12:31 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
Aaron: I thought you were working on your car?
:PERMAGRIN: Joe |
Aaron Cox |
Dec 27 2005, 12:33 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) im going to.... (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) in a bit. not sure what i can do today.... talking with slits..... and i gotta go bend up some rally light brackets |
nein14 |
Dec 27 2005, 12:46 PM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
I have a pair of Rally ST's in my GT, they are truely the most comfortable seats I have had, they won't fit in the backpad.
I carpeted my firewall, the sliders will bolt to the bottom of the seat. The seat frame has to be modified by removing it and splitting it in half to eliminate the tube and tilt bracket. Then fab 2 simple cross supports front & rear drill and use them to mount to the original stock mounting locations on the floor. |
East coaster |
Dec 27 2005, 02:26 PM
John, Do you have any pics of the modified bracketry?
nein14 |
Dec 27 2005, 03:03 PM
No, sorry but do you know Harry from Somers Point with a yellow 914-6 he's a member here. He has them in his car setup that way.
Maybe you can meet up and take a look at his. His user name is har914. |
boxstr |
Dec 27 2005, 03:14 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
You can go to http://www.camp914.com click on the GTS seat icon and then to the Rallye seat, go to the bracket and you will see the pics you are looking for.
Craig C. Laughlin CAMP 914 |
nein14 |
Dec 28 2005, 07:26 AM
They are not the brackets that will bolt into the 914. You have to modify them, it is easier to use the slider from GTS and mod the stock 914 seat bracket.
I worked very closely with Stafan from GTS to get them to work. |
hars914 |
Dec 28 2005, 02:28 PM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
The mounting brackets were an easy mod. I cut the exist. seat bracket in half and
removed the reclining mechanism.Fabed a piece of 1/4" alum. plate with new offset holes drilled to accept the slide bracket.I mounted the plates to the floor bracket then the seat brackets to the plate. I riveted the front of the bracket where it rests on the crossbar. The offset is only about a 3/8" so I had to countersink the holes where it mounts to the floor bracket. It worked great. I will remove the seat and take some pics.The seat height is perfect and I am 6'-2" tall. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:28 AM |
