swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
I've read a number of threads here about the pertronics module and how the 'aw shit' factor comes in. Looks like they have listened.
blitZ |
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States ![]() |
I have a Pertronics module Could you expand on this a bit?
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
maybe I can help here.
A pertronix works very well ( much better than points) when hooked up in a 914 (or any car for argument's sake). It uses a hall effect sensor, which is based on magnets as opposed to a dizzy cam and points. It also elimates distributor cam wear, and from my personal experience, it also made the car smoother running. The problem with the setup is that the hall effect sensor is very delicate and very sensitive to heat. When left on, the sensor is burned out. Apparently, Ignitor II is "smart" enough to shut itself down when the key is left on (good idea). Another note...The quickest way to kill a Pertronix is to hook it up backwards. They got this one solved too, according to the first post. b |
Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
Ignitor II has been out for many years. But it was only made for a couple of applications (Ford V8 and Chevy V8 or something). Maybe they will make one for our cars one of these days.
Demick |
Demick |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Great! now I will buy the 4th one. Every time someone else drove my car they left the key on and burned out the Pertronix. Went thru 3 of them that way at $75 each. points are cheaper.
Cap'n Krusty |
All this improvement after only 30 years? Their response to the design problem is both swift and innovative! The Cap'n
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
The II also has dwell control, which senses the coil charge and adjusts dwell as necessary to reach a particular charge level, rather than doing it based on a fixed time (as the first model does), or on a curve that gets shorter as the revs rise, as points do (and is backwards from what you want).
They don't have all the bugs worked out, yet. I managed to blow up the only Ignitor II I had, anyway. The Ignitor I that replaced it is still working to this day, thousands of miles later. I still haven't figured out what blew it up, but it let the smoke out after a few cranks. Leaving the key on even with points isn't too good for your coil, if the points are closed. Coils don't like being fed current 100% of the time. If you need switched power for some reason with the engine off, disconnect the coil wire. Pertronix quality control has always been pretty hit and miss, and I've found there's a 30-50% chance the unit will be dead in the box. This is really too bad, as it's a great idea. I'm guessing they simply find returning and replacing them to be less expensive than improving their QA. Has Pertronix really been around for 30 years? I was under the impression it was more like 15 years. |
swl |
Do you think all this dwell control and exta goodies of the II will actually accomplish anything or is it just bling? I'm talking about a stock engine not a Raby screamer. The good Cap'ns dry wit makes sense - properly maintained points have worked for 30 years. I'm considering the pertronix just to make maintenance easier and ensure that starts are reliable.
MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
I have a Ignitor II on my car. The dwell adjust thing is supposed to sense cranking and adjust dwell for a faster start. The other new feature is that you no longer have to run a 3 ohm coil or a resistor on your coil. The ignitor II will work with a .6 ohm coil.
Cap'n Krusty |
I've used "Perlux" (which I believe is pre-Pretronix), Crane Allison, and Compufire since the late 70s. In fact, one of the principals at Porschop in LA did a lot of the mechanical R&D for Allison when they started up in the mid 70s. I've had 2 Crane Allison failures out of about 50 units installed One after a few weeks, one after a few years), NO Compufire failures, and nearly 90% failures in Pertronix, most of which came in on a hook after someone else sold them the product. I won't sell 'em. Compufire installs easier, has much better QC, and doesn't cost much more. |
MarkV |
The Ignitor II senses current levels in the coil and adjusts the dwell to maintain peak energy throughout the entire RPM range. Dwell time is increased or decreased with changing engine RPM and operating conditions. This provides more energy at high RPM reducing misfires while improving engine performance.
Compared to point type systems, develops on average 4 times more available energy between 3000 and 5000 RPM and 2 times more available plug voltage. Compared to the original Ignitor develops an average 3 times more available energy between 3000 and 5000 RPM and nearly doubles available plug voltage. Higher RPM performance is improved when used with new Flame-Thrower II super low resistance (0.6 ohms) 45,000 volt coil, however, is compatible with any induction coil. Because peak current level is reached just prior to spark, ignition energy is sustained with less heat build-up increasing coil and module life. Adjusts spark timing over the entire RPM range to compensate for the inherent electronic delay resulting in more stable timing. Senses engine startup and increases dwell time providing more energy for starting sparks. Senses incorrectly wired Ignitor II or a “key left on” condition and shuts down the system protecting the coil and other components from damage. Shares all the same form features as the Ignitor i.e. electronics molded in epoxy for better foul weather performance, no moving or rubbing parts to wear out, fits entirely inside the distributor, no “black box” to clutter your engine compartment, no complicated wiring makes installation easy, compatible with 12-volt negative ground systems and comes with a 30 month warranty. |
lapuwali |
It's really hard to say. Points are crude, but they're effective. If they're treated well, they can last for well over 20,000 miles, meaning you'd have to adjust the valves 3-4 times between points replacement, so the maintenance isn't really improved all that much. On a conservatively tuned engine, you'd probably not notice the difference between new-ish points and any Pertronix. The whole "high precision" thing can be taken too far. I recently checked the timing on my 912, with a fresh distributor and fresh points. At idle, the timing was pretty rock solid. By 4000rpm (normal cruising speed on this engine), the spark scatter was so bad the timing mark was blurry and actual timing was somewhere in a 5-8 degree window from event to event. Pretty much puts paid to the whole idea of getting timing set within one degree. I'd venture that unless you're going all the way to multi-coil crank-triggered ignition, the differences are too small to bother with on most street engines between one type of ignition and another. Being able to accurately keep the timing within a degree and get the coil charge exactly right, etc., is no doubt useful when you're building a very high performance engine, as you can tune the thing a lot closer to the point of blowing up w/o crossing that line. On a mild daily driver, however, the difference is a lot less important. |
swl |
but any time not spent with my butt in the air and my head down in the engine bay is worth it! Getting too old for that nonsense! Cap'n - sounds like you've seen enough of these that your stats are solid. No failures is a pretty good number (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Since reliability is my primary concern going with compufire sounds good. I'm going to replace the coil and wires as well. Any thoughts about doing the full DIS-IX kit? Further reduces wearout parts by eliminating the rotor and cap. These look like they are designed for type 1. If memory serves type one doesn't have the 2 longer spark plug ends. I found one vendor that offers it without the wires. DIS-iX kit |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Increased spark accuracy (timing) as well as advance changes benefit ANY engine! As a matter of fact they benefit those "Non Raby screamers" more than anyone would believe.
This is the facts... The pertronix / compufire replaces points, it's still based on the sloppy mechanicals of the 009 dizzy with its lack of initial advance adjustment and it's non adjustable advance curve. Install the pertronix into a 009 slightly "Polishes a turd".... and while it's better it still isn't going to give you more power, MPG or reduce head temps. Installing the DIS-IX is a "Super turd polishing" experience.... They call it a "Distribtorless ignition system" but its not! How the hell can you have a DIS system when its based on a distributor and it still uses that distributors crappy advance mechanism?? That system is no better than the dizzy it's sitting on top of as it's no more accurate or adjustable than the crappy 009 was to begin with. Whats the real answer??? Two words: Mallory Unilite Accuracy and adjustability with no need for a little magnetic sensor because it has an optical pick up.... I have about 80K miles on the cap and rotor on the one in my 912E and every car I own has one, I even made a retro fit for the Pinzgauer and modified it to work with 24 volts- that gave me 4 MPG on a big ole honkin Austrian military truck and much better throttle response at low revs in low range 4X4. If I noticed a difference in a 5,000 pound truck turning 34" tall tires the difference can be noted in about anything. Buy a Mallory. set it. Forget it. Four years later when you verify the timing it'll still be exactly where you set it. Try that with a 009. |
lapuwali |
IMHO, those DIS kits are nearly worthless. They still rely on the mechanical advance curve from the distributor, and the 009 advance curve is utter crap.
swl |
Damn I love this place! More accumulated knowledge than you can shake a stick at! Means however that there is no such thing as an easy answer!
Did some more reading. The 009 is a type one distributor. Ours is a 050? The compufire will fit in the 050 with 'some distributor modification'. I really didn't set out to replace the distributor - is the standard distributor as bad as the 009? Adjustable is not necessarily good unless you know what you are doing. |
Jake Raby |
"050" is the same body as the 009, same internals as well.. Just a different advance curve... It was originally designed for the 616 engine that uses a Hemi chamber, it was not designed for the TIV engine.
IMHO its WORSE than the 009, it sets up horribly retarded at idle and unless you run 32+ degrees of full advance it jas less than 5 degrees initial advance at idle. This is why it worked wel on the 616, they love high advance due to the semi hemi chamber. It's sixties technology- today it's 40 years behind the times. The adjustability is a good thing, especioally when you buy one pre set for use on a TIV engine, thats the only way I sale the mallory- ready to install, no tweaking needed, unless you want to.. Many people are happy with the 009 and the 050, most have never experienced the difference of a better arrangement.. It's almost like a cable/DSL connection- once you leave dial up you can't go back! |
solex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States ![]() |
Is is possible to upgrade the stock DJET with a Mallory Unilite?
lapuwali |
Finding an 050 isn't all that easy, either. You can't buy them new, anymore.
If you're still running FI, you can't use anything but the stock distributor. If you're running carbs, then just hold your nose and get a Mallory Unilite. It's very reliable. I'm sure Jake can measure a difference between one ignition setup and another, but still, IMHO, on a street engine, you'll not be able to FEEL or otherwise detect the difference without a dyno. My butt isn't so finely calibrated I can tell the difference between 100hp and 105hp, and I suspect most butts are equally bad at measuring this. |
Lo-Fi Version | Time is now: 3rd July 2025 - 10:52 PM |
