Flared cars, what size rims are you guys running |
STL914 |
Dec 28 2005, 11:30 PM
Senior Member Group: Members Posts: 1,180 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest |
Thinking about adding flares to my 72 and I like to know what the general thinking is as to wheel sizes, diameter and width, front and rear.
Thanks |
SirAndy |
Dec 29 2005, 12:07 AM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
standard GT flares (7"/9") street: 7" cookies cutters front & rear with 1 1/4" spacer in the front, 1 1/2" spacer in the rear, 225/50 x 15 tires. track: 7" cookie cutters front & rear with 1/4" spacer in the front, 1/2" spacer in the rear, 9" x 15 goodyear racing slicks (R250) future street: 8" x 16 ronal alloys in the front, 9" x 16 ronal alloys in the rear. i'd like to run 245/45 in the front and 285/40 in the rear, but i can't find anyone who makes the 285/40 in 16 anymore ... probably going to settle for 225 in the front and 245 in the rear ... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Andy PS: oh, yeah, just in case you're wondering, i have 5-lug 911 suspension. |
John |
Dec 29 2005, 12:12 AM
Track car 9x16 FUCHS replicas front and rear (245/45 R16)
Street car (in progress) 8x16 FUCHS replicas front and rear. The factory steel GT flares have plenty of room for wider wheels. It kind of depends on your wheel spacers and the wheel offset as to how wide you can really go with the GT style flares. |
VegasRacer |
Dec 29 2005, 04:57 AM
ELVIRA Group: Benefactors Posts: 8,524 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Factory GT steel flares.
225 - 50's all the way around on real 16 x 8 chrome Fuchs. The next set of tires will be 245 - 45 - 16's. Looking to buy something the same size or 7's & 9's for the track. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge24.gif) |
RON S. |
Dec 29 2005, 06:41 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
10"s baby.go all the way (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Ron Attached thumbnail(s) |
ken914 |
Dec 29 2005, 07:26 AM
Whole lot 'O 914/6 Group: Members Posts: 157 Joined: 15-November 04 From: Mount Pleasant, SC Member No.: 3,122 |
Fuchs. 7x15 front, 8x15 rear. 225s front and 245s rear.
nein14 |
Dec 29 2005, 09:14 AM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
15 x 8 Fuchs all around w/225 x 50 x 15 street tires
15 x 7 Minilites 1 1/8" spacers all around w/225 x 50 x 15 Pole Postion SO 3 track tires |
STL914 |
Dec 29 2005, 09:05 PM
Thanks for the responses. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
John, (nein14) I sent you a PM. |
John |
Dec 29 2005, 09:13 PM
Ron,
Those appear to be ever so slightly wider flares than the standard GT flares. Are they 1" wider? |
Eric_Shea |
Dec 29 2005, 10:01 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
I don't know how you guys do it. I've got 7" and 8" Fuchs and my rears are full with factory steel flares. There's a good 1/2 inch there but that's about it. Now up front I think there's room for 14"s (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Not doubting... I've heard enough stories of the 9" and even a few 10"s. Maybe it's my big old style 15" tires. |
John |
Dec 29 2005, 10:16 PM
Eric,
We have been running the 9x16 FUCH replicas on the track car for the last 12+ years. I went to find a set for my current project and found they were no longer made and that the used ones were in high demand (944 & 911 guys). I settled for 8x16 for my street car project. I have seen 10" on the rear but the GT flares had been widened. |
Eric_Shea |
Dec 29 2005, 10:18 PM
Like I said... not doubting. It's probably my tires.
iamchappy |
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I have the 245 45 16s on 8's and 225 50 16s on 7s up front very comfortably.
I have about 1.5 in the rear to play still allowing about 1/2" inside and out. I would like to widen my rear flares to support a 17" 285 or 315 for the Jack Olson look 914. |
dennisc |
Dec 29 2005, 10:25 PM
Member Group: Members Posts: 90 Joined: 1-September 04 From: Marshall, MO Member No.: 2,671 |
Hi Gary
I am running 7 & 8 x 16's with 225 front and 245 rears. 1/4" spacers on rear. You need to look at my car to see what you think. |
Aaron Cox |
Dec 29 2005, 10:29 PM
just a point of interest....
7's fit fine under stock front fenders. i have 7" and 205's and 8" and 225's under nearly stock rear fenders... (1" pull or so...) (IMG:http://www.914world.com/bbs2/uploads/blog-1134520586.jpg) 9's SHOULD be an easy fit under GT flares.... ive seen 10's with the right offset fit.... |
Eddie914 |
Dec 29 2005, 10:52 PM
Unregistered |
Front: HPH full fiberglass fenders, 16x8 BBS RS et11 225/50/16 Yokohama a032r - 25mm + fender clearnace
Rear: HPH fiberglass flares bonded to stock fenders 16x9 BBS RS et2 245/45/16 Yokohama a032r 7mm spacers (hub to rotor) - minimal tire to fender clearance (tires rub due to worn wheel bearings and possible trailing arm flex) |
Eddie914 |
Dec 29 2005, 11:15 PM
Unregistered |
Here is a pic
Attached image(s) |
smac |
Dec 30 2005, 02:22 AM
Newbie Group: Members Posts: 39 Joined: 17-June 05 From: westminster Ca Member No.: 4,294 |
Sorry, I couldn't resist! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Attached image(s) |
914Sixer |
Dec 30 2005, 12:23 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have steel factory flares on my conversion with 15x8 Fuchs with 215-60-15 tires for streets use.
STL914 |
Dec 30 2005, 07:52 PM
Hi Dennis, Thanks for the info on your car's set up and the offer to look at it. I was leaning towards 15 inch wheels but then again alot depends on what's available when I decide to buy. Can you send me a larger image of your avatar to my e-mail address? |
Lo-Fi Version | Time is now: 8th June 2024 - 01:24 PM |
