Moved the car, now I get to start working on it! |
Mike Pearson |
Aug 24 2003, 11:34 PM
I *am * in shape; ROUND is a shape! Group: Members Posts: 29 Joined: 2-July 03 From: Seattle, WA Member No.: 876 |
Thanks for all the hints and tips on turning the car 90 degrees without an engine and on a hill. We got it pulled around this morning.
We used a single 2-1/2 ton floor jack, 2 chunks of plywood (only about 18" wide, one about 6 feet and the other about4 feet), a come-along, and 100' of new rope. Wrapped rope around tree and through one of the front tow points, hooked up come-along and we were able to get it turned about 45 degrees, but still needed to come over a concrete 'step' to get it into position. We wound up dricing a 4' pipe into the ground at the corner of the house and moving the rope from the tree to the pipe. Once we got it real close to where I wanted it we got everyone together and we picked up the rear end and rotated the car about one more foot. Not too bad...only a little over an hour from start to finish. Now it's in a place where I can actually work on it. Next step is to get the shop area cleared out, get a new workbench in there, and then pull the engine and see how much damage the water in the cylinders did. The right side does have a lot of sag, so I know that I'll be replacing the longitudinal and rockers. I'll see what other structural stuff needs to be done as I go along. |
Brad Roberts |
Aug 25 2003, 12:54 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Pics.. Mike.. Pics ..
Just because it is sagging on that side.. doesnt mean it needs a frame rail. B |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:15 AM |
