front oil cooler, which side for lines |
spunone |
Jan 4 2006, 07:02 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Has anybody routed there oil line on the drivers side .You know remove plastic hoses open up the holes and use new line for oilcooler??Just thinking out loud (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Aaron Cox |
Jan 4 2006, 07:13 PM
i used the right side.... so the hot oil lines dont bother me.... just the passenger. do a search in the forum and my blog..... where are you tapping the oil from? sandwich plate? full flow? makes a difference which side is easier..... AA |
spunone |
Jan 4 2006, 07:16 PM
You really think the oil lines will get hot enough to bother you when mounted on the out side ?? (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Aaron Cox |
Jan 4 2006, 07:18 PM
umm....look at how the factory did it. its in the car for 8 inches or so..... search is your friend paul. AA |
Aaron Cox |
Jan 4 2006, 07:20 PM
here are a few iterations....
(IMG:http://www.914world.com/bbs2/uploads/blog-1126053052.jpg) (IMG:http://www.914world.com/bbs2/uploads/blog-1125714178.jpg) you can go into the fenderwell and up and over the strut.... like some people do...... |
Aaron Cox |
Jan 4 2006, 07:21 PM
1 bklahkhdfjhdfj
Attached image(s) |
Aaron Cox |
fwgtrjkl
Attached image(s) |
Aaron Cox |
Jan 4 2006, 07:22 PM
3e678'[-p
]iuyjgtrf Attached image(s) |
Aaron Cox |
qewrtyuiopiuytr
Attached image(s) |
Aaron Cox |
Jan 4 2006, 07:23 PM
erthjkhgfdasfk
Attached image(s) |
Aaron Cox |
Jan 4 2006, 07:25 PM
dion9146 |
Jan 4 2006, 10:14 PM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
The previous owner of my car ran his radiator lines stright up the middle under the center tunnel. (it was a V8 car) Would have been nifty if there was actually a recess there. I guess his train of thought was that if he bottomed out in this area, he probably had bigger issues than worrying about the cooling lines. However, I would be worried about road junk constantly battering the lines.
Dion |
SirAndy |
Jan 4 2006, 10:24 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
there *is* a recess there, along the center tunnel ... however, for oil lines, i still like the idea to run them outside along the rockers or inside the long or inside the cabin. in fact, i like inside the cabin, along the pass. side long, the best. put a alu cover over it and you should be safe (and cool) ... like this: (IMG:http://www.914world.com/bbs2/uploads/post-2-1087692164.jpg) read THIS thread for more info on oil-line routing ... http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=13396 (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy |
dmenche914 |
Jan 4 2006, 10:28 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
can't agree more with a cover, hot oil under pressure can give a nasty burn, although it is much cooler than radiator fluid, for which you for sure need protection from leaks. Learned from experience, ouch!!! it was hot!!!
GeorgeRud |
Jan 4 2006, 10:38 PM
Running them outside along the passenger side rocker, then up into the gas tank ( as shown on the black photo 2 posts ago) area behind the strut is really easy and you won't burn ourself or your passenger with hot oil lines.
Trekkor |
Jan 4 2006, 11:44 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Attached image(s) |
spunone |
Jan 5 2006, 08:47 AM
Tanks for all the pics guys and yes Aaron it's a full flow oil system .Just tryin to figure out my plumbing set up Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
Nick |
Jan 5 2006, 09:11 AM
Member Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 |
I agreed with the folks that say keep the oil lines out of the passenger area in case something bad happens. Here are some pics of my car:
Attached image(s) |
Nick |
another
Attached image(s) |
Nick |
Jan 5 2006, 09:12 AM
final
Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 12:57 PM |
