removing CV from a 930 axle for V8 914, boot is torn. |
Dr. Roger |
Jan 6 2006, 12:15 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
i removed the little clip on the axle already but what a beeeatch.
i used my MSFH (medium sized effin hammer) to no avail. am i doing something wrong?? any tips or tricks??? roger Attached image(s) |
drive-ability |
Jan 6 2006, 12:34 AM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
The only thing that holds the axle in on my 930 trans is the clip you removed. You may have some burs on the splines near the clip grove... It just may need more pressure to remove it.
(IMG:http://members.cox.net/altjamy/Hannah-Porsche%20062.600.jpg) |
Dr. Roger |
Jan 6 2006, 01:14 AM
it definately does not just slide out.
i'm afraid if i "motivate" it at the wrong place i might screw something up. where would you hit it? the widest part of the flange? damn nice pic BTW. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) got a pic of the whole beast? |
Andyrew |
Jan 6 2006, 01:29 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
What exactly are you hammering??
Cus the shaft is one piece. Im sure you know that. Are you hammering the outer cv away from the shaft? Dont have any advice, havnt done that before... |
redshift |
Jan 6 2006, 01:55 AM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Wuss! Put some freaking oil in that thing! M |
Dr. Roger |
Jan 6 2006, 02:24 AM
the only way i know how to replace the boot is to remove the CV joint. am i blowing it? is there another way to replace the CV boot? i honestly don't know squat about 914's. i'm giving myself a crash course over the last year... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Gint |
Jan 6 2006, 09:01 AM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I agree that the C-clip is the only thing holding that shaft onto the joint at this point. Well the boot is also to a very minor degree. You need to get it off of the joint. And you got some good advice from drive-ability. Check for burrs before following the suggestion below.
Remove the metal collar of the boot from the cv and move the boot up the shaft and out of your way. Place the joint on the top of your vice with the center section flat on the top and the shaft in between the jaws of your vice just wide enough for the shaft and to allow some play. Get a helper to hold the shaft below the vice to keep it from falling on the floor. Whack your shaft with your MFH. Make sure your square so you don't screw it up. It shouldn't take much, the thing lives in grease. Here's a caveat BTW. Do not try to hit the outer portion of the CV to remove it from the shaft. You will fu the joint. This post has been edited by Gint: Jan 6 2006, 09:02 AM |
Dr. Roger |
Jan 6 2006, 11:21 AM
thanks mike, i knew there was a trick to that. this is just like mike muellers custom tool for removing the rear hubs and wheel bearings.... another great trick. =-) |
Lo-Fi Version | Time is now: 8th June 2024 - 05:05 PM |
