hole spacing for engine to trans |
Tom |
Jan 7 2006, 12:50 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Hi guys, I'm trying to get a bracket made to adapt my regular engine stand to be able to put the type four engine on it. Anyone know the distance between centers for the two top bolts at the rear of the engine? Are the top and bottom bolt distances the same? I have a couple of brackets here, but need to know where to drill the holes. I am at work or I would measure it myself. Here at work I have access to a good drill press also.
Thanks, Tom |
bd1308 |
Jan 7 2006, 12:58 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
you dont have to fab one up, there are some already available...
check pelicanparts.com b |
736conver |
Jan 7 2006, 01:15 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Whats the fun in that. Building stuff is always more fun. Gives you a better sense of accomplishment too. Sorry dont have any dimensions for you though. Everything is bolted up and I wouldnt be able to give you some good numbers. I sure someone here has a car apart that can help, maybe one or two guys. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Tom |
Jan 7 2006, 01:45 PM
Thanks, I thought the TEENER'S creed was to do it yourself if at all possible, then when it is done, you can enjoy the fact that you did it yourself. Besides, if I order one, I won't be able to put the engine on the stand until it comes in.
Tom |
Lo-Fi Version | Time is now: 8th June 2024 - 09:27 PM |
