Distributor Problem, Self Destruction??? |
d7n7master |
Jan 7 2006, 11:26 PM
Gary# Group: Members Posts: 663 Joined: 13-March 03 From: The O.C, Ca. Member No.: 421 |
I was replacing the O'Ring on the distributor shaft prior to installation on my new long-block when I noticed that a 'lil piece of something fell on the floor.
I picked it up. It looked like a piece of a washer or? So now I'm wondering where it came from... I gave the distributor another spin - & sure as $hit - two more pieces fall into my hand. WTF??? Check this out: (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Attached image(s) |
Allan |
Jan 7 2006, 11:31 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Sounds like the channeled washer that pulls oil up to the shaft. If that is what it is, yer lucky you found the pieces before starting the motor. I'm not sure where to get them new but I found mine easily at a place that rebuilds t4 bus motors...
dmenche914 |
Jan 8 2006, 12:19 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
check a local VW aircooled store or dune buggy store.bring it in, and they should be able to match the washer thingy for your engine.
SLITS |
Jan 8 2006, 09:57 AM
You could feasibly remove them from a used dizzy....it doesn't have to be the one specifically for your car as there were many varations of the dizzy that used those washers.....
Dave_Darling |
Jan 8 2006, 12:11 PM
Nope--that part is down underneath another part, not on the bottom of the distributor itself. Remember, there is a separate "distributor driveshaft" that slides into the case. It has a gear on the bottom and slots on the top. The two tabs we see on the bottom of the distributor slide into the slots on the top of the distributor driveshaft. The washer you're thinking of goes on the bottom of the driveshaft. The fiber washer probably sets end-play on the distributor. Chances are probably pretty good that you can find the parts at a VW specialty shop. Measure the thickness of the pieces, just in case you need that info. --DD |
Allan |
Jan 8 2006, 12:27 PM
OOPS, yep.
Not the metal washer. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:43 PM |
