Rust repair help, wind shield pillar and under sail |
spunone |
Jan 10 2006, 01:18 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Starting on rust repair lower windsheild pillar both sides have rust and pitting along with small holes under roof sail panel,. Do I need to cut out the pitting and weld in new pcs or is there something to kill the rust and fill in the pitts .Must be compatable with car paint since this is on the outside.Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
Bartlett 914 |
Jan 10 2006, 02:37 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I am currently replacing the windshield cowl. I thought there was a small amount of surface rust. The windshield was broken so I removed it. I found there was a lot more rust under the windshield seal. This can be a trouble spot. Water collects under the trim and quietly rusts away. I am not trying to scare you but that is what I found. Removing the trim is a little tricky without damage but it can be done. I 'm sure you can find info on site for this. Ultimately you will need to be the judge if you are going to take this plunge and go this far. I think most will agree that welding in metal is better than fiberglass or other solutions.
Lots of luck! Mark |
spunone |
Jan 10 2006, 02:43 PM
Thanks I have some rust but not that bad as your pic maybe sand out what I can and por patch to smooth? what ya think?>?
wertygrog |
Jan 10 2006, 02:57 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
hmmm the area below the sail panel has rotted through on my 74, can i just chop the section out and put a new one in? or is there an easier solution? What is behind that crease where the metal goes vertical for the sail panel.
brent |
r_towle |
Jan 10 2006, 03:07 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
here is my humble opinion...
The windshield frame...if its not to bad...wire brush on a drill or grinder, phosphoric acid to kill the rust... Then you could either weld and grind to built it back up, or bondo. the sail panel... Behind it is foam, in the vertical section...the targa bar is several layers, with a corrugated section in the middle to add strength... The factory would put foam in there, between the middle layer and the outer panel...the foam traps water and then it rusts... I would but the sail panel patch from restoration design and cut out the panel, remove the foam for ever, and weld in the new panel. For rust you want the following stuff Wire wheels on a drill for light work, a grinder for more aggresive work. Some sort of phosphric acid rust treatment..navel jelly is one, there are lots more.. Some sort of auto paint compatible primer.. Possibly some POR 15, or the metal ready product as well.. And of course, bondo..gotta have that... Good luck. Rich |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:57 PM |
