| racergreg |
Jan 11 2006, 04:02 PM
Member ![]() ![]() Group: Members Posts: 91 Joined: 4-April 05 From: Fullerton, CA Member No.: 3,869 |
Ok, the 6 is bolted in (a very cool CIS 2.4). Everything is working out great, I have the oil plumbing going in fine. NOW, the question is how to connect the throttle cable. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
The stock connection (one of those little balls mounted on a bell crank) is carefully wedged in between the velocity stacks and the CIS pump unit, only a couple of inches from the rear sheet metal. In the 914, the ball needs to be pulled toward the BACK of the car. From what I can tell, the cable will need to be mounted behind the sheet metal, and then go through a hole to the linkage. Can anyone share some ideas or pictures? I would really appreciate it. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
| brant |
Jan 11 2006, 04:10 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,112 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Greg,
here is my version. close to stock -6 except the stock version screwed into the tranny a couple of inches forward of mine. most people make a 3rd version that bolts onto the tranny a little forward of mine too. Attached thumbnail(s)
| brant |
Jan 11 2006, 04:11 PM
My car doesn't happen to have tinwork..
but most cars should/do and then would have a hole in the rear tin for rod to pass through: Attached thumbnail(s)
| GeorgeRud |
Jan 11 2006, 04:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
The rod to the transmission is just like that on a 911 (since it's cable comes from the other end of the transmission in a 911), so the geometry is the same. The bell crank is unique to the 914-6, but the pictures are quite representative.
The 914-4 and 914-6 throttle cables are different though, so you should use the correct one. |
| john rogers |
Jan 11 2006, 04:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
On my race car we did not use the stock bellcrank and linkage, but used a 4 cylinder cable and made a small aluminum bracket at the back of the engine and the cable routes under the engine and in the rear sheetmetal. The cable pulls towards the rar of the car with mine. A lot less moving parts and those ball joints that tend to pop loose at times.
| racergreg |
Jan 11 2006, 04:26 PM
Thanks so much, guys, that is perfect, just what I needed! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
| brant |
Jan 11 2006, 04:31 PM
I should have mentioned John's way too. Lots of people make their own bracket and avoid the bellcrank with good success.
Also, regarding the -4 and the -6 cables We made a cable end that screws onto a -4 cable but still has the ball connector on it. since is screws on, it can be reused on other -4 cables. Its much cheaper to buy -4 cables, and much easier to borrow -4 cables at the track. brant |
| thesey914 |
Jan 11 2006, 04:32 PM
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
this method might make the cable bind..
| Aaron Cox |
Jan 11 2006, 05:04 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
mike Z had a good no belcrank linkage on his six...
similar to a four banger setup |
| brant |
Jan 11 2006, 10:20 PM
Just for clarification. With the mounting point we used, our bellcrank is neither 911 or 914. We cut the original brazing and then readjusted the angles of the levers to fit our application and needs, before reattaching them. |
| Dave_Darling |
Jan 11 2006, 11:50 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,301 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The Bird carries a bolt-on bellcrank setup that uses the stock (cheaper) four-cylinder cable. It is fairly similar to the other bellcrank setup pictured earlier.
http://www.pelicanparts.com/catalog/shopca...x_pg1.htm#item5 (IMG:http://www.pelicanparts.com/catalog/images/six_conversion/accel.jpg) --DD |
| rick 918-S |
Jan 12 2006, 12:48 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,142 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Link says no longer available. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
| 914Timo |
Jan 12 2006, 01:32 AM
******* ![]() ![]() ![]() Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
It sure did. Thats pic from my carb. I used stock 914-4 cable, but the problem was that the cable was too short and it had to make too tight turns => cable bind (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Now I have bellcrank system (did it myself) and I am very happy with it. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| jetboy |
Jan 12 2006, 02:11 AM
914 Uber Noob ![]() ![]() Group: Members Posts: 205 Joined: 16-September 05 From: Riverside, CA Member No.: 4,810 Region Association: Southern California |
Ive seen the same thing for a few months now. If they are available then i would like to know. Does anyone else make one? Im not that crafty to make one myself (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
| thesey914 |
Jan 12 2006, 04:55 AM
Timo....can you post some pics?
| Dave_Darling |
Jan 12 2006, 12:38 PM
Oops! That's what I get for not paying attention... No idea if or when it would be in stock again. Maybe if enough people pester Wayne? Rich Johnson sells a replica of the original Six setup. You have to drill and tap into your intermediate plate to mount it, but it looks all nice and OEM that way... --DD |
Lo-Fi Version | Time is now: 12th December 2025 - 09:06 PM |
