terrymason |
Member ![]() ![]() Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 ![]() |
I'm looking at a 72 1.7 914, and was hoping to get some info from you guys. The owner said that it had a leaky fuel injector. The car starts and drives, but smells like gas, and is really lacking in power.
Looking in the engine, the driver side has two knobby things (I'm guessing they're the injectors), and there's a puddle of gas under them. Any idea what it would cost to replace these injectors? I'm pretty good with a wrench, but would it take any special equipment? |
chas |
Newbie ![]() Group: Members Posts: 24 Joined: 30-November 05 From: seattle,wa Member No.: 5,214 ![]() |
Easy with hand tools,injectors 20.00 to 100.00 on ebay.Get a book.
terrymason |
awesome. Can you recommend a good book?
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Get a Haynes Manual, it's pretty good and fairly cheap. Shop around or you can get it online at pelican Parts
Before you replace the injector check the fuel lines to them. They get old and cracked. FI hose is kind of expensive but cheaper than injectors. Dave |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
And make sure you use fuel hose clamps, not the usual ones that cut into the line when tightened. I would bet your hoses are cracked, though.
terrymason |
Dave, thank you soo much for mentioning that. I was going to replace the hoses anyway, but it never crossed my mind that they would be "fuel injection" hoses, as opposed to fuel lines. FI is under like 100 psi pressure right?
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
~40 PSI or below that.
DNHunt |
I know 2.0l D-jet runs 29.5 PSI. I assume the 1.7 is the same.
Use good hose and good clamps. 914's burn really well with some magnesium parts. Don't mess with fuel system compromises. Dave |
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
Some advice on an old car, get a maintain a fire extingusher in your car.
in the leaking injectors, they can leak in several ways externally. The hoses can leak, and leaks can develop between the plastic body and metal parts of the injector. The first case is repairable, the second case i have no known cure, so replace. On original injectors, the two inch or so hose is factory crimped to the injector, making replacement seem impossible. However with a pair of tin snips, and hacksaw you can carefully remove the factory metal crimped hose clamp, and then replace the hose, using a screw on hose clamp (as stated by other poster, use an FI rated smooth hose clamp, not the ones with the teeth cut into the band) be careful when working on the injectors, the plastic body is not the toughest thing, and can crack/leak if bumped a bunch. ideally you should obtain the correct L-shaped hoses for the ends of the injectors, however you will need to find them from a Porsche or VW place. otherwise I have been able to run regular straight hose, just bend it, it may look like it is restricting fuel flow, but it is not and will work fine. System pressure is just under 30 psi. Also replace any suspect looking fuel lines you see in the engine bay, be sure all existing hoses in the fuel system engine bay are FI rated, if the hose is not marked as such, be suspect, a prior owner might have used the wrong stuff, and it can fail suddenly. Also there are some hoses near the fuel filter and under the gas tank (access from under car) inspect and replace if suspect. the ones in the engine bay are most important, cause of all the heat there, and potential for fire, but then again, any gas leak is bad, make sure the thing is leak tight before parking inside. Don't want to burn the garage down. the haynes manual is a good source of info, there are some other books, but they are a bit harder to find (out of print???) There is plenty of info here so ask. |
Lo-Fi Version | Time is now: 11th July 2025 - 11:57 AM |
