Tighten belt 2.0, how to |
ventilator01 |
Jan 17 2006, 02:47 PM
Member Group: Members Posts: 127 Joined: 22-November 05 From: Thomaston, Ga 30286 Member No.: 5,166 |
Went for a long ride today ( found a cool road that curves alot and kinda goes up a mountain) anyhow when I first cranked it up I heard a chirping noise and then some when when going fast heard it again, pretty sure a belt needs to be tightened. I checked the haynes and it kinda tells which bolts to loosen, but does not get into the first part, like how to get to it ect. Is this done from top or bottom, any tips appreciated.
thx steve ps is there just one belt? its a 2.0 |
SLITS |
Jan 17 2006, 03:11 PM
One belt......two black plastic hole covers on driver's side engine tin....you'll need a 4 mm allen hex wrench to loosen the pinch bolt (one under the front plastic hole cover)......
ventilator01 |
Jan 17 2006, 03:55 PM
From the top or underneath?
rhodyguy |
Jan 17 2006, 04:04 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
top, or inside the engine compartment.
k |
ventilator01 |
Jan 19 2006, 08:56 PM
Mine seems to be a half inch socket, then I used a half in open end wrench to hold the nut , is there a trick to getting the alternator pulled tight, when i get my hand around and get it pulled tight theres not much room to get another hand in there to tighten it back up. I think I actually need to replace the belt, thers only about a quarter inch left to pull the alternator. thx steve |
Dave_Darling |
Jan 20 2006, 01:12 PM
There's a second little plastic cover on the side of the engine tin. You can reach through the hole that cover is on to push the alternator down, while you tighten the pinch bolt through the front hole. You should not need to hold the nut on the back of the bracket; it should have a tab on it that keys into the slot on the bracket.
--DD |
Lo-Fi Version | Time is now: 10th June 2024 - 11:14 PM |
