pist. rings, 1.7 |
pist. rings, 1.7 |
toon1 |
Jan 18 2006, 10:49 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I am getting ready to put my 1.7 back together. I can't seem to find piston rings for 90mm bore. Are the vw rings the same? Is it ok to clean the rings that are there break the glaze on the cyl. and reuse? will they reseat?
SLITS |
Jan 18 2006, 11:46 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
toon1 |
Jan 18 2006, 01:54 PM
Thank's, I happened to find them @perf. prod. as well. they were about $12 cheaper than Deves.
What can I look for on the old rings to tell if they are still usable or not? |
bd1308 |
Jan 18 2006, 01:58 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
i think you can tell if they're good or not by measuring the gap in the ring??? b |
SLITS |
If you want to reuse them, go ahead. There is really nothing to look for other than to stick them in the bore and measure the end gap.
MattR |
Jan 18 2006, 02:01 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Remember, if you do replace rings you have to hone the cylinders.
toon1 |
what is a good end gap measurment? |
SLITS |
Jan 18 2006, 02:32 PM
The specifications will be given in the manual........
You should also check the side clearance in the ring land. |
Bleyseng |
Jan 18 2006, 04:19 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
like this
Attached image(s) |
toon1 |
Jan 19 2006, 11:20 AM
Anyone use autohausaz, Grant brazilian rings
toon1 |
Jan 19 2006, 01:03 PM
anyone.....anyone.....bueller....bueller........
Bleyseng |
Jan 19 2006, 01:10 PM
I just put those on the 1.7L Blair and I are rebuilding. Haven't run it yet.
Lo-Fi Version | Time is now: 8th June 2024 - 04:42 PM |
