911 Combo Oil Temp & Press Gauge, Will it work in a 914??? |
vesnyder |
Jan 22 2006, 09:53 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I want to replace my dash gas gauge/e-brake light gauge with an oil pressure/temp combo gauge. Can I hook this up without any major issues? I have a '73 with the standard Type-IV engine.
Thanks |
Bleyseng |
Jan 22 2006, 10:08 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
You need the correct senders and need to hook up the oil pressure one on a rubber brakeline to extend out. The senders are 911 ones that need to be the correct ones for the year on the combo gauge.
(IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) Attached image(s) |
vesnyder |
Jan 22 2006, 11:40 AM
I appreciate the need for a correct temp sender, but can you provide some detail on
Anybody have a "tech article" discussing? Thanks |
Bleyseng |
Jan 22 2006, 12:12 PM
Its just a short rubber VW brake line that you screw into the oil pressure senders location. I use a dab of sealant on the threads so it won't leak. The dual can sender screws onto the end of the brake line and you attach it with a clamp onto the tin or fan housing.
The oil temp sender screws into the same spot as the stock one (taco plate) |
Bleyseng |
Jan 22 2006, 12:19 PM
pic
Attached image(s) |
anthony |
Jan 22 2006, 02:03 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Are you adding another fuel gauge to the car? |
vesnyder |
Jan 22 2006, 03:36 PM
anthony - My intent is to move a gas gauge to the center console - is that possible/recommended? Anybody have a good source for a stand alone gas gauge that is the same size as the console gauges?
Bleyseng |
Jan 22 2006, 03:38 PM
I made mine outta parts from the gas gauge and the oil temp gauge. I posted how I did two years ago.
J P Stein |
Jan 22 2006, 04:20 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I have a gas gauge that is now excess to my needs. It is made to work with the stock gas tank sender and is "supposed" to be the right size for the console (tho I never had it mounted there).....but the best news is that it's cheep. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
johnmhudson111 |
Jan 22 2006, 05:01 PM
Member Group: Members Posts: 491 Joined: 29-November 04 From: Nesbit, MS Member No.: 3,191 |
I used the 150psi dual sender (from Pelican parts) and I was able to screw it into the stock location. It reguired that I cut some of engine tin due to the larger diameter but, it is another option to a remote mounting.
Also, I bought the regular oil temp sender for a 914 and it works in the 911 gauge, my car was not orginally equipted with a oil temp sender. I don't know if there is any difference between the 911 and 914 senders. |
Bleyseng |
Jan 22 2006, 09:55 PM
here is the chart
Attached image(s) |
vesnyder |
Jan 23 2006, 06:18 AM
Bleyseng - Thanks for the info. Do you have a post to how you did it?
JP - Interested in the gas gauge. Left you a PM. |
anthony |
Jan 23 2006, 11:41 AM
If you have a console then why not just put an oil pressure gauge there and then keep the stock fuel gauge?
vesnyder |
Jan 23 2006, 02:12 PM
I want the critical engine info (oil temp and pressure) up where I can see it, and I will put the "nice to have" info such as voltmeter and fuel level down where I occasionally glance. Just something different as well - more like the 911. I'm a 911 guy at heart!
Lo-Fi Version | Time is now: 8th June 2024 - 11:33 AM |
