Shock dimensions?, Struts and shocks... |
jhadler |
Jan 31 2006, 05:28 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
So... I have a little extra money to invest in the car, and I came up with a list. On that list was getting my single adjustable Konis converted to double adjustable. Unfortunately, the prices I've found for the conversion are still a bit out of range.
Then I got to thinking... The roundy rounders know how to make good race parts, custom built, and tend to cost a good deal less than the gold plated world of Moton and the like. Does anyone have dimensional specifications of the front strut inserts and rear shocks? Body OD Body length Free length extended Compressed length And any other structural specs? I'd like to hunt around to see if there any existing options from the roundy round tuners. Oh yeah.. The list... 1) Set of Circle racing wheels (15x8 @ 13 lbs each) and a set of camber plates from Elephant Racing (or just the monoballs and a MegaSquirt ECU kit) 2) Set of Kodiak racing wheels (15x8 @ 10 lbs each) 3) Converted/Double adjustable shocks. 4) Save it for other stuff, like a new helmet, roll bar, and incidental expenses... The logical choice would be 4, and is the front runner. But 1 and 3 are still in the hunt... Thoughts? -Josh2 |
914werke |
Jan 31 2006, 05:57 PM
"I got blisters on me fingers" Group: Members Posts: 10,124 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
How much is it to rebuild/convert single adustable (old style) Konis to dbl adjustable?
jhadler |
Jan 31 2006, 06:06 PM
You're gonna love this... Okay, there's three places to go for converting Konis to double. Pro Parts True Choice Koni N/A Pro Parts wanted around $600 per corner in front, and $400 per corner in back. I've also found a bit of negative feedback about Pro Parts, so would be hesitant to go there. True Choice wants around $700 per corner in front and $600 per corner in back! (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) I have yet to hear back from Koni North America, but would be surprised if they were alot cheaper. But who knows... For contrast, a set of custom built Pensky's would be $750 a corner. Any length, any size, any valving. Geez.... -Josh2 |
jhadler |
Feb 1 2006, 11:53 AM
groot |
Feb 1 2006, 01:43 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I have double adjustable Konis on both ends and spent much less than that for new units.
I bought them from Koni NA. My brother used to work at Pro Parts West, but he couldn't get his pricing any longer, so I went with NA. I will not give money to True Choice ever if I can help it. I'm using 8611s in the front... downside is the compression adjustment is on the bottom. I have 3011s in the back, which required some mods to the mounts... which should be done anyway IMHO. The stock setup puts the damper in bending. BTW.... I have my old set of 8611s that I may be able to part with. It turned out to be only a wee bit more expensive to buy new ones (and I got them a bit shorter to allow a little more travel). |
jhadler |
Feb 1 2006, 01:49 PM
PM sent
Lo-Fi Version | Time is now: 7th June 2024 - 05:27 AM |
