| SirAndy |
Feb 1 2006, 12:58 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
anyone got a picture of the pin-layout of a early vs. a late Headlight Switch ???
(IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
| SLITS |
Feb 1 2006, 01:53 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
I prolly have both...will look, but I just count the pins.......
ein, zwei, drei, vier.......links, rechts, links...oy, vait ein minuten. |
| Bleyseng |
Feb 1 2006, 02:06 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Mixing Dutch and German....now thats really bad. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/jsharp.gif)
| SLITS |
Feb 1 2006, 02:28 PM
| michel richard |
Feb 1 2006, 02:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
okay, which is which
| SLITS |
Feb 1 2006, 02:37 PM
the one with 10 pins is early....the one with 11 pins is late.....or try babelfish translation (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif)
| lapuwali |
Feb 1 2006, 03:05 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
And how many pins are actually REQUIRED? Just 4:
1 +12 in 2 +12 out to side, tail lights (1st position) 3 +12 out to main lights (really, hi/lo switch or relay) (2nd position) 4 +0-+12 out to dash lights (dimmer knob) The difference is what's split inside the switch v. what's split outside the switch. |
| Flat VW |
Feb 1 2006, 04:28 PM
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
I could use a '74 one (late, huh?).
I at times must jiggle the switch to make the lamps come on, just a matter of time. Are they still offered new anywhere? John |
| richardmosselman |
Feb 1 2006, 04:31 PM
slvr bullet ![]() ![]() Group: Members Posts: 390 Joined: 18-September 05 From: Victoria BC Member No.: 4,822 |
That's funny! I have to jiggle mine too (no dirty hijacks please!) So, I'm going to require an early one ('72)?
| SirAndy |
Feb 1 2006, 04:40 PM
ah craps, just what i thought ... oh well ... i got a really nice *early* switch. anyone wanna trade for a nice *late* switch ??? (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
| lapuwali |
Feb 1 2006, 04:51 PM
If you (Andy or anyone) can cope with doing some rewiring, VW switches look nearly identical, have the same functions (two pull positions + twist dimmer), but have fewer terminals and are FAR cheaper. Like I said earlier, the only difference is in what splitting goes on in the switch v. in the harness, so you'd have to devise an adapter "harness" to connect the 914 harness to the VW switch, but it's doable. Same on early v. late 914 switches, really.
I think the only visible difference between the 914 and the VW switches besides the number of terminals is the rubber part of the knob is very slightly different. However, the 914 knob will fit on the VW switch, so even that difference can be nullified. The price difference is pretty startling: $20-30 (www.cip1.com) v. $400+ (Pelican), so it's well worth the effort to rewire. |
| SLITS |
Feb 1 2006, 05:00 PM
How 'bout you PM me an address and I send you a "late" switch...used, unknown, but.............. |
| SirAndy |
Feb 1 2006, 05:03 PM
well, that would be nice ... (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
| SLITS |
Feb 1 2006, 05:06 PM
Slits is not nice, but Ron will do it...... (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
| Dave_Darling |
Feb 1 2006, 05:59 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Brad Anders was able to open up his headlight switch and clean it up and repair it. Might be worth a look... http://members.rennlist.com/pbanders
--DD |
| Aaron Cox |
Feb 1 2006, 06:44 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
Ron, can you clean off the late switch so i can read the terminals???
muchas gracias.... it *gasp* may help me fix some gremlins.... |
| SLITS |
Feb 2 2006, 05:11 PM
Cleaned, labeled and parfumeed for the little Corona engineer......toot toot Oh, you need to look at the image a few posts above....then scratch and sniff.......... |
| Aaron Cox |
Feb 2 2006, 05:19 PM
thank you
| Aaron Cox |
Feb 4 2006, 12:13 AM
ron was off on a few pins....
ironically, i think this solves my foglight problem. Attached image(s)
| Aaron Cox |
Feb 4 2006, 12:25 AM
just for reference in case someone does a search in the future...
this is a fog light/rear defrost switch (same switch - different knob insert) should be able to read the 3 terminals.... Attached image(s)
Lo-Fi Version | Time is now: 2nd April 2026 - 12:41 PM |
