Fuel hose diameters, & inline pressure adapter |
yarin |
Feb 7 2006, 05:52 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I'm redoing all of the fuel lines with this project. I bought steel brake lines from NAPA for about $4 a piece following pelican's article. I might end up bending the lines with a tube bender instead of using a 90deg fitting.
These are the sizes i've gathered so far: Supply: 3/8" Return: 5/16" Fuel Rail: 5/16" Fuel pressure regulator: 5/16" Fuel filter: 3/8" I'd like to put an inline fuel pressure gauge near the fuel rail using this stuff: 1/8" fuel gauge 0-60psi 1/8" in line 3/8" adapter How did you guys put the 3/8" inline on the fuel rail side? With a 5/16" -> 3/8" adapter? Or did you end up placing the inline gauge on the 3/8" side next to the fuel filter? |
Mueller |
Feb 7 2006, 05:55 PM
my gauge is inside the engine compartment (fuel pump and filter up front)...used a "t" similar to that fitting and plumbed in before the pressure regulator........
yarin |
Feb 7 2006, 05:59 PM
A 3/8 tee or 5/16 tee? |
Mueller |
Feb 7 2006, 06:20 PM
i'm pretty sure my fuel line is 8mm...so 5/16" |
yarin |
Feb 7 2006, 06:21 PM
Any idea where I can get that adapter in 8mm / 5/16" ?
It doesn't seem to exist anywhere. |
Lo-Fi Version | Time is now: 8th June 2024 - 06:25 AM |
