914-6 alignment specs, optimum suspension settings for the stre |
SC850R |
Sep 3 2003, 07:49 PM
Newbie Group: Members Posts: 6 Joined: 21-April 03 Member No.: 595 |
I would appreciate any suggestions anyone might have for alignment specs. My car is a 2.7 liter 6 with a 911 front suspension and 7 and 8 inch fuchs ft and rr. I had the car realinged as suggested by a local tuner and it went from predictable, understeer to a tail happy, unstable beast that tries to swap ends even with highway lane changes. My hope was to optimize the performance of the car, but its really unstable now (keep in mind I like neutral to slight oversteer, but this is unsettling (IMG:style_emoticons/default/ohmy.gif) ). High speed sweepers are a nightmare!
BEFORE left front> -0.7 camber right front> -0.3 camber left rear> -0.6 camber right rear> --1.8 camber toe at the front was 0.15 (toe out I think) toe at the rear was 0.00 AFTER left front> -1.1 right front> -1.2 left rear> -1.2 left rear> -1.3 toe at the front> -0.03 toe at the rear> -0.05 What do other people use? Why did the car change so dramatically? Could the toe change have had such a dramatic effect? There were no changes in the tires or tire pressure. Help |
ArtechnikA |
Sep 3 2003, 08:15 PM
QUOTE(SC850R @ Sep 3 2003, 05:49 PM) BEFORE toe at the rear was 0.00 AFTER toe at the rear> -0.05 ... Could the toe change have had such a dramatic effect? if by these numbers you mean you went from 0 rear toe to some toe out, you betcha. rear toe out is BAD. (a little up front can help turn-in on the AX track). too little toe up front (either direction) can make the car twitchy - the tires need to have some preload slip angle before they can be responsive. you didn't mention caster, but too little can hurt stability too. try for as much as you can get - typically around 6 deg is what you get - it should just be the same side to side. |
redshift |
Sep 3 2003, 08:38 PM
I don't like all that camber, rear around -1, and back to about what you had up front, -.7 or so..
Street, stock tires. I am with Rich, having rear toe is like driving a car with super heavy rear springs, and no front swaybar, except worse. M |
si2t3m |
Sep 3 2003, 08:50 PM
914 addict Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 |
Hi, on my 914-6 conversion (3.0, 911 front end with underbody swaybar, 6's up front and 7's rears, no rear swaybar) :
0 toe front -1.3 camber front -1.7 camber rear Caster was maxed out but event on both sides. 0 toe front 1/16 toe-in rear All this was done with me (200lbs) in the car with a 1/2 tank of gas. Car felt pretty good at the last DE. It's a bit twitchy on the highway due to the 0 toe front but i like it that way. Marc-André |
SC850R |
Sep 3 2003, 09:44 PM
I think the minus 0.05 toe in the rear is toe in, but I could be wrong. If it is toe out that would explain a LOT!
scotty |
Sep 3 2003, 09:45 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
You've got to have a front swaybar (and dangit, your wheel/tire combo is nice!)
I have 6" wheels with 195/65 tires all-around... My settings are pretty close to Marc-André's (-1.0f/-1.5r camber and I run 1/16" more toe in all around f/r, caster at 6.0)... before I installed the front bar (now at full on -- full "off" was as good as no bar), the car was... "exciting" (IMG:style_emoticons/default/ohmy.gif) to drive in a spirited fashion. Now it's fine. |
Brad Roberts |
Sep 4 2003, 01:24 AM
Marc has good settings. Unless your good friends of this alignment guy.. you need to find a new one. I have NO idea where he came up with your numbers.
Oh.. welcome to the BBS ..ha ha (IMG:style_emoticons/default/clap56.gif) B |
SC850R |
Sep 10 2003, 06:51 PM
Guess what folks- it was toed out in the rear! The guy's reply to me when I brought the car back to them? "Oh yeah thats toe out- yeah it will make it squirrlley (sp)!" And they returned the car to me this way why?????? (IMG:style_emoticons/default/mad.gif) Thanks to everyone for their help!
Lo-Fi Version | Time is now: 7th June 2024 - 06:34 AM |
