Plenum removal, Noob question |
Rand |
Feb 13 2006, 08:11 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
How is the plenum fastened down on a '75 2.0? (IMG:http://www.914world.com/bbs2/html/emoticons/051103-stupid4.gif) Once the intake runners are off, what else needs to come loose to get the plenum off?
There are a couple of holes in the plenum next to the throttle body with tubes running through the plenum, but I couldn't find a screw head in the bottom of those. There's a tab on the drivers side with a screw in it, but that didn't let it loose. I had just started taking it apart when I got a call and had to drive... So I put everything back with a new gasket between throttle body and plenum, and found a couple of small cracks near the tubes that run through the plenum. Sealed those with tape for now. It did drop my idle and there's a little bit of a whistle now. My fast idle problem is just about narrowed down to a cracked plenum. Before I dig in again I'd like to know exactly how it's fastened. |
rhodyguy |
Feb 13 2006, 08:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
there's one bracket on the rear too
Attached image(s) |
Dave_Darling |
Feb 14 2006, 01:07 AM
I believe that there are two "feet" on the sides/front of the plenum. Those go to some of the screws that hold the engine tin onto the top of the crankcase. Plus there is the tab shown above that runs to the crankcase seam at the back. It is held on by one of the through-bolts.
--DD |
Rand |
Feb 14 2006, 01:17 AM
Thanks Kevin and Dave!
I had missed the bolt in Kevin's photo... Very helpful... Kevin, I'm buyin' you a beer someday. Also noted, that bolt is a major grounding point for the FI wires. Getting closer... intake manifold gasket replaced on one side. All intake runner sleeve/seals replaced. Back together, fired it up, runs good, putting palm over intake killed it... Good sign. We'll see how it runs for the commute tomorrow. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:21 PM |
