Shift Rod removal, How do you get it out of the tunnel? |
Jaiden |
Feb 15 2006, 11:57 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
I've tried every way I can think of except pulling it out the back through the bushing Is that the way to do it? I just can't get it to come out of the shifter hole.
I 'm doing Por15 in the tunnel and I don't want to get any on the rod. Suggstions? |
JWest |
Feb 15 2006, 11:58 AM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Side-shift?
Jaiden |
Feb 15 2006, 12:00 PM
Tail Shift
gopack |
Feb 15 2006, 12:01 PM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
I need to know too!
watching closely! (IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) |
lapuwali |
Feb 15 2006, 12:28 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
You pull it back out through the bushing. No way it will come out up front. If the engine is in the car, it's possible you won't be able to completely remove it, but you can probably get enough of it out of the tunnel for your purposes. Sideshift bar will not come out of the car with the engine in place, but I now can't remember if I could sneak the tailshift rod past the mount bar or not.
Jaiden |
Feb 15 2006, 01:52 PM
hmmmmmm.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) I think I'll just zip tie it up off the bottom and Por-15 away!!
Thanks! |
rjames |
Feb 16 2006, 03:43 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Are you going to use the Por-15 sealer or the metal ready stuff they make? There's a long thread here somewhere that I started regarding both products (search my username if nothing else). From what I learned from everyone elses input, simply sealing it up won't help with the rust, make sure you treat it with Metal Ready first. I'm about to do the same thing, hoping I caught it in time. Part of me woders if I couldn't just cut open the tunnel, treat it, or at least cut sections of it open at a time, then just treat that area, close it back up, then open another segment and repeat....sounds like too much work though. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:08 PM |
