Long Wheel Studs |
Long Wheel Studs |
EdwardBlume |
Feb 18 2003, 04:09 PM
Where can I find some longer wheel studs to fit 2.0 Fuch w/ 0.25 spacers, and have enough thread to keep the wheels on?? Normal Fuch studs are too short. Any ideas would be great!!
(IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) |
Dave_Darling |
Feb 18 2003, 04:16 PM
Long long ago, in a California town far away (OK, actually Sunnyvale) a Glossy Catalog outfit used to sell extra-long wheel bolts that worked with 914 wheels.
You might check the company that bought them out (different California town). Or you might try talking to your other favorite Porsche mail-order outfits, you never know... They might be able to get them as well. --DD |
Part Pricer |
Feb 18 2003, 04:21 PM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
or, you could call Tire Rack and tell them that you need extra-long wheel bolts for a VW Passat (B5).
Dman |
Feb 18 2003, 04:34 PM
Member Group: Members Posts: 163 Joined: 18-February 03 From: Sacramento CA Member No.: 311 |
Are you looking for long studs, or long wheel bolts?
EdwardBlume |
Feb 18 2003, 07:49 PM
(IMG:style_emoticons/default/ar15.gif) I'm looking for the wheel bolts. A local mechanic said that 924 Turbo studs worked but couldn't find any.
Passat bolts? Really. Thanks, R (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) |
Sammy |
Feb 19 2003, 09:17 PM
. Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
The 924 bolts are not quite long enough. There's a place in Orange Ca. that sells longer bolts, real german stuff too, they're a VW web based mail order shop, wish I could remember the name. fairly cheap last time I bought em, they have two or three different lengths. Might want to check out a hot VW magazine, maybe they have an ad. I'll search around and see if i can come up with a name.
EDIT: I found the reciept, the place is called virtual World Parts inc. (714) 633-9924 or go to www.parts4vws.com The bolts were uhhhh, pretty darn cheap, $2.50 each for the 35 or 42 mm lengths. |
EdwardBlume |
Feb 21 2003, 01:28 AM
Thanks good tip.
Much obliged. |
Lo-Fi Version | Time is now: 12th June 2024 - 05:50 AM |
