A-arm end cap, Replaceable? |
Jaiden |
Feb 28 2006, 11:03 AM
Member Group: Members Posts: 346 Joined: 13-January 05 From: Stroudsburg PA Member No.: 3,443 |
So I got a another a-arm but the end cap is missing is it even possible to replace this?
Eric_Shea |
Feb 28 2006, 12:47 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Yes, they're available. Call PP and ask for the torsion bar end cap. They used to have them in the online catalog. If not call Porsche... only a couple bucks each.
Spoke |
Feb 28 2006, 01:13 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
James,
Did you need the end cap? It should still be sitting around the garage if you want it. The adjustment bolt is sitting in the red car; looked at it last night. The end cap can't be far away. My buddy in Andreas (near New Ringgold) had a bunch of suspension parts. I'm going to call him tonight to see about a replacement rear trailing arm. I can ask him if he has any if you would like. Spoke |
Jaiden |
Feb 28 2006, 04:18 PM
Thanks guys,
How do you install the cap? On my original A-arm I appears that it was pressed in and then the end was clamped in place. There was a plastic shim there but no metal cap. You guys know what I mean right? On the front end not the torsion adjuster. Thanks again spoke let me know if you find it. |
r_towle |
Feb 28 2006, 04:24 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
From what I recall, its just pressed in.
I took mine out to remove the torsion bar...then just put it back in...carefully. I have a few cars worth of suspension if you need something.. If you can wait, I am going to Hershey... Rich |
Eric_Shea |
Feb 28 2006, 04:30 PM
yup... just pressed in. You may want to whack it with a plastic mallet to spread it out a bit and hold it tight.
Lo-Fi Version | Time is now: 7th June 2024 - 06:43 PM |
