> someone please write a dissertation on LSD's, Quaife, ZF, torsen, lockers, phantom's..
Aaron Cox
post Mar 4 2006, 09:53 PM
Professional Tinkerer
blows my mind... im interested in how each one works, and the effects of it on acceleration (lock unlock etc) for each of them....
would be a great wealth of knowledge to have in one place....
bueller?
Replies(1 - 19)
TimT
post Mar 4 2006, 09:56 PM
retired
(IMG:http://www.914world.com/bbs2/html/emoticons/tunez.gif)
its not rocket science...
Aaron Cox
post Mar 4 2006, 09:57 PM
tim, you can sing about LSD's if thats your style (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
TimT
post Mar 4 2006, 10:01 PM
retired
Not sure what your looking for exactly... As LSDs have been discussed ad nauseaum....
SLITS
post Mar 4 2006, 10:02 PM
"This Utah shit is HARSH!"
1. Put tiny piece of designed square paper onto tongue and let disolve.
2. Experience dillusions for up to 14 hours.
(IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Aaron Cox
QUOTE (TimT @ Mar 4 2006, 09:01 PM)
well make me dizzy....
in one thread.....
J P Stein
post Mar 4 2006, 10:11 PM
Irrelevant old fart
The only thing I know about LSDs is that I have had one on order since Nov 11 2005 and still haven't gotten the fucker.
Them Hawaiian gear cutters are doing too much surfin' and not enuff cutting. Supposedly, the next batch should be here about yesterday or the day before........which is still too damn late.......shit.
pek771
post Mar 4 2006, 10:20 PM
http://auto.howstuffworks.com/differential.htm
The basics. I'm curious about this Phantom Grip deal.
Aaron Cox
post Mar 4 2006, 10:30 PM
QUOTE (pek771 @ Mar 4 2006, 09:20 PM)
just read the whole thing... knew most of it...
now id like to learn about each one's behavior in accel/decel conditions... and cornering
alpha434
post Mar 4 2006, 10:31 PM
My member number is no coincidence.
Dude. Where's the young gun action? You have to know two-three times as much as the old guys do. That's the rule.
All limited slips consist of clutch mechanism(s) and a spring to hold the clutch(es) down. This way there is a lot of resistance to slipping. And it will slip when there is a lot of force telling it to, like when turning. And no slip (or very little) when your coming down the straightaway.
The difference between manufacturers is either quality (parts tolerancing and failure prevention) OR novelty (achieving the same effect a different way.) Not usually both.
The phantom grip isn't really a limited slip. It's positive traction. It locks both differentials when there is positive pressure coming from the pinion. And it unlocks when there isn't any pressure. They even sell spring kits on their site to be able to adjust responsiveness, i.e. how much pressure locks the diffs.
A limited slip, posi-trac, locked, or open differnetial drastically changes how you have to drive on the track. If you're used to powering hard through corners, then an improperly tuned Phantom Grip will literally make your car "undrivable." But maybe a locked diff would be ok, because then you just have to push hard enough to break the tires loose.
But now I'm past answering you question and I'm blabbering.
alpha434
post Mar 4 2006, 10:35 PM
QUOTE (Aaron Cox @ Mar 4 2006, 08:30 PM)
Glad you asked.
PG: Can't power through the corners or the diffs will lock
LS: Easy to set proper spring pressure for cornering.
Locked:Have to be able to break the tires loose, or you'll push yourself off the track.
Opem:Best cornering, since the axles are free to change speeds. Hurts you on the straights, where you've only got one wheel driving you at any given time.
pek771
post Mar 4 2006, 11:01 PM
Regarding the Phantom Grip...
I looked at their website, but there wasn't much info. I'm really not sure how their unit operates. First I even heard of one was today, when XHead (Fiat guy) mentioned he has experience with them.
Also, being old, I seem to recall the difference between limited slip and Posi-Traction is that Posi-Traction is a copyrighted name belonging to General Motors. I don't recall a Ford ever having Posi-Traction.
Pat
bondo
post Mar 4 2006, 11:06 PM
QUOTE (pek771 @ Mar 4 2006, 10:01 PM)
Pat
Ford had trac-lock as their trademark. Posi-trac and trac-lock are both clutch type. I think alpha is thinking of the "detroit locker" which fully locks on acceleration.. which I *think* is what the phantom grip is a variant of.
alpha434
post Mar 4 2006, 11:10 PM
Could be. I've actually never worked on an american car.
bondo
post Mar 4 2006, 11:12 PM
Limited slip
Locker
alpha434
post Mar 4 2006, 11:20 PM
Yeah. My definition of posi-trac was hearsay from an idiot. I should've known.
Dr. Roger
post Mar 4 2006, 11:29 PM
A bat out of hell.
one strange thing about lockers is that if you go into a turn and accelerate out, the locker will lock. then your turning can get a little weird if your not used to it. most people stay out of the throttle on slow turns. Or gun it.
LSD set at about 80% is my preferrence.
alpha434
post Mar 4 2006, 11:33 PM
QUOTE (Dr. Roger @ Mar 4 2006, 09:29 PM)
Like I said. You can change those springs to set the response. Tighter springs will make it so that the locker doesn't lock as quickly.
The 80% is usually a good choice.
Everything depends on the track that you're at.
sixnotfour
post Mar 4 2006, 11:38 PM
18 types to choose from;Use the "select diiff. " box and enjoy the selection.
http://reiderracing.com/differentials.htm#
pek771
post Mar 4 2006, 11:47 PM
It seems the useful combinations we would consider are the open, Quaife type, ZF type and the Phantom Grip. The lockers are impractical, and the track cars would just run a welded rear.
I know there is a difference between the Quaife and the ZF, because I hear the autox guys rave about the Quaife, and the track guys say they suck.
- Lo-Fi Version Time is now: 2nd April 2026 - 02:54 PM
