I Know I've Said This Before..., Pulling the Trigger w/Pix |
kconway |
Mar 6 2006, 02:44 PM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I think I've finally found "the" car. This is a '74 2.0 car that I was unable to find rust in.
Couple of things that bother me but prolly not enough to pass. 1500miles on engine & trans rebuild. Check me out on these, I'd like opinions. 1. Biggest issue I have is some PO put a "vehicle computer" in the dash. Not sure I know what it was suppose to do but it no longer works. He hacked up the dash just to the left of the radio where the vent controls were and moved those just to the right of the steering column. Just pull cables. (I'll post a pic of this (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) when I can). 2. Rear trunk hood paint is faded. 3. Rear end was tapped and will have to be pulled and fixed 4. Is the rear end sitting low? Can you tell without knowning tire size info? 5. Lastly, little hesitation/stuttering between 2K-3K RPM, perhaps throttle switch or MPS? Whaddy think Attached image(s) |
kconway |
Mar 6 2006, 02:45 PM
two
Attached image(s) |
kconway |
Mar 6 2006, 02:46 PM
three
Attached image(s) |
kconway |
last one
Attached image(s) |
Brad Roberts |
Mar 6 2006, 02:49 PM
Looks nice. Needs rear springs to get the ass end off the ground. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
B |
Root_Werks |
Mar 6 2006, 02:53 PM
Village Idiot Group: Members Posts: 8,332 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
That looks like the Alaska Blue Met. Love that color. (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif)
kconway |
Mar 6 2006, 02:56 PM
Confirmed, L96B Alaska Blue Metallic. Original throughout.
Does the dash have a "subframe" that bolts in? I'm going to want to put the original vent controls back in somehow. |
SLITS |
Mar 6 2006, 02:58 PM
It's blue & looks nice...with the painted bumpers you didn't get sway bars did ya?
1.) If you need a stock dash frame to move things back to normal...just ask...have a couple before they get sawalled. 2.) At least it isn't crashed in or dented 3.) Picture don't look that bad to go thru the trouble (unless you're gonna paint it) 4.) Brad says yes, so get new springs...not that expensive 5.) Any number of things that you'll sort out when you take it home. Buy it before Howie finds out....... |
Eric_Shea |
Mar 6 2006, 03:00 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'd say, if you found a rust free 914, the rest is inconsequential.
kconway |
Mar 6 2006, 03:01 PM
Ron,
You wouldn't happen to have a dash frame in L96B would ya? Do these "bolt in". I'll post pix of the dash when I pick it up in a new thread. Hopefully the wiring isn't butchered when they put in this 'computer'. |
SLITS |
Mar 6 2006, 03:38 PM
Dash frames were not painted...just rusty steel....I should have two of them. They " bolt in". or I have a 914/6 dash frame and you can fake out your friends... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) or I can supply an X1/9 dash if you wish (IMG:http://www.914world.com/bbs2/html/emoticons/av-943.gif) |
914-8 |
Mar 6 2006, 07:25 PM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
Interestingly, it seems a lot of dash frames are that Alaska blue metallic color - even in cars that were not Alaska blue! At least that's what I've seen quite a bit in the past. |
Aaron Cox |
Mar 6 2006, 07:41 PM
first thing i said when i saw the pics looks nice (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
jim912928 |
Mar 6 2006, 08:35 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
rear end looks good...just lower the front to match...get LOWWWWW
Lo-Fi Version | Time is now: 5th June 2024 - 05:19 AM |
