outside door handle repair |
sk8kat1 |
Mar 7 2006, 09:53 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
how hard is it to fix the mounting screw if it is broken off...
jimtab |
Mar 7 2006, 11:25 PM
Advanced Member Group: Members Posts: 3,477 Joined: 5-January 03 From: Pacifica, California Member No.: 91 Region Association: Northern California |
The guy you need to get hold of is ury914, Paul is the guru of handles...he just fixed both of mine....give him a shout. Jim
Cap'n Krusty |
Mar 7 2006, 11:44 PM
Mark Britell does door handles .............. The Cap'n
lotus_65 |
Mar 8 2006, 05:47 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif)
i put a new handle on my car, but it still won't open the door. i can reach in (without the handle) and pop the door fairly easily but i don't want to force it. what else do i need to do? |
GaroldShaffer |
Mar 8 2006, 09:12 AM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Mike, Back when I had my 73 914 the mounting screw broke off the driver side handle. I took the handle off and drilled out where the mounting screw went and I think I used either a 10mm or maybe it was a 8 mm bolt about 3/4 inch long. Put the handle back on with lock washer and nut and every was fine. You couldn't tell unless you were looking for it. YMMV |
URY914 |
Mar 8 2006, 09:20 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,983 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) If only the screw (stud actually) is broken off, just drill through it and put a bolt in it. Paul |
sk8kat1 |
Mar 8 2006, 10:26 AM
woohoo!! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) that's great news ... thanks guys ---
URY914 |
Mar 8 2006, 10:38 AM
So this means you found a lefty handle?
Air_Cooled_Nut |
Mar 8 2006, 03:13 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Buck914 |
Apr 15 2006, 10:58 AM
Newbie Group: Members Posts: 6 Joined: 1-November 05 From: Tomball, TX Member No.: 5,050 |
If the outside retainer tab is broken I am right to assume the unit is terminal? JB Weld crossed my mind but my mind has been simpled out lately. If terminal do I just go to all the usual suspects? (IMG:style_emoticons/default/pray.gif)
markb |
Apr 15 2006, 03:50 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
If the outside retainer tab is broken I am right to assume the unit is terminal? JB Weld crossed my mind but my mind has been simpled out lately. If terminal do I just go to all the usual suspects? (IMG:style_emoticons/default/pray.gif) Send it to URY914, he can repair it. |
URY914 |
Apr 16 2006, 05:35 AM
If the outside retainer tab is broken I am right to assume the unit is terminal? JB Weld crossed my mind but my mind has been simpled out lately. If terminal do I just go to all the usual suspects? (IMG:style_emoticons/default/pray.gif) If the mounting tab is broken off it can be fixed. The complete story is in my blog, but ... Take a picture of it or send it to me and I'll let you know what it will take to fix it. Paul Woodbury 6713 Drifting Sands Drive Temple Terrace Florida 33617 Here are some pictures before and after of a broken tab... Attached thumbnail(s) Attached image(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 01:55 PM |
