> Torsion Bar Spring Rates
joea9146
post Mar 10 2006, 09:22 PM
Searched around and found this : But which one is correct ?
Front Rates
Torsion Kw (lb/in) Ks (lb/in)
Dia (mm) (Wheel) (Spring)
16 77 90
17 97 112
18 122 138
18.5 137 154
19 152 170
20 187 207
21 227 249
22 273 298
23 327 355
> SIZE ( mm) SPRING RATE ( Lb/in)
> 18.8 110
> 21 173
> 22 210
> 23 250
> 24 296
> 25 350
Replies(1 - 19)
Sideways
post Mar 10 2006, 10:13 PM
They are both correct, one is for the front end the other rear of a 911.
The chart for the front lists both Wheel rate and actual bar rate. The spring rate is different at the wheel due to basic leverage.
TimT
post Mar 10 2006, 10:17 PM
retired
What??? you got some splainin to do
Joe did you find some of the info at Instant-G?
Aaron Cox
post Mar 10 2006, 10:18 PM
Professional Lawn Dart
here is the instant G one...
http://instant-g.com/Data/911CoilConv.html
Sideways
post Mar 10 2006, 10:31 PM
QUOTE (TimT @ Mar 10 2006, 09:17 PM)
When a bar, coil spring etc is manufactured it has a certain rate, the spring rate. #200 for eg.
The wheel rate is measured at or around the hub of the wheel (It s the spring rate the wheel 'see's').
Ie leverage comes into play, generally the wheel rate is lower that spring rate because the wheel is attached to the spring via a lever (the A arm) the difference between spring and wheel rate depends on the location of the spring and the length of the lever (among other things).
In the case of a 914/911 the spring is at the piviot point of the arm and the lever is the lengthof the arm from the bushes to the plane of the hub.
Does this help, this is very simplified......
ArtechnikA
post Mar 10 2006, 10:48 PM
rich herzog
QUOTE (Sideways @ Mar 11 2006, 12:31 AM)
it doesn't help me understand why a spring would have a different rate if it's at the rear rather than the front, if that's what you mean.
wheel rate, sure, but that wasn't the question...
TimT
post Mar 10 2006, 10:53 PM
retired
Occams razor
actually it doesnt help a bit..
When I buy 600# spring for our 935... Im buying a 600# spring..
Im well aware of spring rates, K values etc.. I know about the ratios that delta "x" will impart to the spring/torsion bar etc..
wheel rate and spring rate are intimately related.. as they will be
but one thing in the relationship is constant... the spring rate..
(unless of course it is a spring system made from variable rate springs)
TimT
post Mar 10 2006, 10:55 PM
retired
Ha!! Rich said it more succinctly than I
Sideways
QUOTE (ArtechnikA @ Mar 10 2006, 09:48 PM)
Sorry, I should have separated that sentence, the wheel rate comment was separate to the front and rear torsion bar piece.
The torsion bars are a different length front to rear hence the different rate for the same thickness bar. (rear bars are longer)
Aaron Cox
post Mar 10 2006, 10:58 PM
QUOTE (TimT @ Mar 10 2006, 09:53 PM)
Occams razor
i love this place... latin prods, and spring rates in the same post (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif)
In its simplest form, Occam's Razor states that one should not make more assumptions than needed.
i learn stuff everyday
Sideways
Occams razor
Wheel rate is also effected by any friction in the suspension, bushings etc, however your 935 suspension would be all but devoid of this.....
Sideways
post Mar 10 2006, 11:02 PM
Thanks for the latin lesson, based on this my first response should have read.
Both are correct. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
TimT
post Mar 10 2006, 11:07 PM
retired
there is friction.. not much though
Aaron, Occams razor is a concept to keep in mind!! its good stuff..
Im an engineer that lives in the KISS... environment..
Sideways
post Mar 10 2006, 11:09 PM
QUOTE (TimT @ Mar 10 2006, 10:07 PM)
I'm just a dumb ass that cannot get my thoughts from my brain to my fingers...... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
TimT
post Mar 10 2006, 11:10 PM
retired
And Steven
Welcome to the club
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png)
all is good.. we can all learn
(IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Sideways
post Mar 10 2006, 11:12 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) Self confessed....
Tim how do you like the Haltech systems, A friend of mine used to work fro them is Australia.
(IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) Over...
TimT
post Mar 10 2006, 11:18 PM
retired
Haltech is good.. user friendly.. easy to tune...
at least from my experience.. we have a bunch of cars out there running Haltech.. no problems that I know of
joea9146
post Mar 11 2006, 08:47 AM
OK.... so a front 21mm torsion Bar Has a spring rate of 240 lbs ???
ArtechnikA
post Mar 11 2006, 09:11 AM
rich herzog
QUOTE (Sideways @ Mar 11 2006, 12:55 AM)
good point. you are correct.
i was misdirected because i've never seen a 911 rear bar as small as even a very large front bar. but a quick look at the parts list shows that SWB cars had 22 and 23 mm rear bars and there are (now) 23mm+ fronts, so it is possible.
Sideways
post Mar 11 2006, 09:35 AM
QUOTE (joea9146 @ Mar 11 2006, 07:47 AM)
You are correct.....
- Lo-Fi Version Time is now: 31st July 2025 - 07:13 AM
