> Alternator light stays lit...., Any idea's on what?
montoya 73 2.0
post Mar 11 2006, 08:54 PM
Lack of consideration to others, and Selfish!
Already replaced the regulator and put new belt on. Could it be the brushes? If so, Is it possible to find replacements or could it be something else? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I was told by a local mechanic that it may not be worth fixing it, that I should just replace the alternator.
As the RPM's get higher, the light get's brighter.
Replies(1 - 5)
bd1308
post Mar 11 2006, 08:57 PM
Sir Post-a-lot
fuse #7 (from left)
if that goes out, nothin works right.
check your connection at the starter, mine came loose and screwed up everything, blew out my radio.
etc etc. check wiring. could be brushes too.
b
montoya 73 2.0
post Mar 11 2006, 09:06 PM
QUOTE (bd1308 @ Mar 11 2006, 06:57 PM)
fuse #7 (from left)
b
I checked the connections and fuses first. I thought I'd start cheap first and then work my way to expensive. Do you know where I can find brushes? I called a local foreign auto place, and they said they can't locate any. But the bastards can sell me a new alternator!
post Mar 11 2006, 09:07 PM
if your alternator is bad, look in your yellow pages under Alternators.
There are tons of places that can rebuild your alternator for relatively cheap. $75-$100.
bd1308
post Mar 11 2006, 09:12 PM
Sir Post-a-lot
NAPA/Beck Arnley rebuilds them
CarQuest does too, my CQ dizzy works fine.
someone even does brushes, but i dont remember who...B-A maybe?
b
montoya 73 2.0
post Mar 11 2006, 09:18 PM
I'll check on monday about having it rebuilt. Is there anything that I should be aware of if having it rebuilt?
- Lo-Fi Version Time is now: 19th September 2025 - 01:22 PM
